-   Carburetors and Carb Tuning.. (https://rotarycarclub.com/forumdisplay.php?f=95)
-   -   Carb Manifolds (https://rotarycarclub.com/showthread.php?t=14286)
infernosg 06-10-2011 12:12 PM
Carb Manifolds
Although I won't be using a carb, but rather a DCOE- or IDA- style throttle body I figured this would be the best place to ask. I know there are a few readily available intake manifolds out there but I'm curious what everyone's using. So far everything I've seen for IDA's has different runner lengths between the front and rear rotors (for obvious reasons) and I haven't found any DCOE manifolds that fit my application ('86-88 turbo irons). If anyone went custom who built your manifold? I haven't been able to locate a fabricator yet!
730RWHP12A 06-10-2011 06:48 PM
i have manifolds that fit the 86-88 turbo lower manifolds, so you can install the sidedraft throttle body.
infernosg 06-10-2011 09:41 PM
I guess I forgot to mention that I don't have the stock LIM. My car originally had a S5 n/a motor in it but now I'm doing a 4-port n/a build using S4 turbo irons. From what I've found none of the DCOE manifolds are equal length either.
730RWHP12A 08-14-2011 10:37 AM
so, you could use a factory turbo 2 lower manifold , with the wrap around upper :)
as far as i know, if you want an equal length intake manifold you will have to have a custom manifold fabbed up.
good power can be made with whats available out there tho....
are you looking to make maxium hp, or just have fun?
infernosg 08-15-2011 12:37 PM
Yep, I could try to dig up a TII LIM somewhere. I have some guys looking into fab'ing a manifold for me but if that falls through I'll have to follow your advice for the time being.
Not looking for maximum HP - more like a useable HP range. I'd be happy with ~200 whp at 8000 RPM with decent torque in the 4000-8000 RPM range. I'm building the car for HPDE and eventual TT/PT use.
2gslse 08-20-2011 11:02 AM
do you have one for a 13B-REW ??? it is on the website but no pics of one
730RWHP12A 08-20-2011 02:25 PM
i will post pics of the manifold as soon i get it back from the machine shop.. you know, the usual..... ill keep you posted. im going to have a few done, so they will be on the shelf, there wont be delays
