Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > ZN Performance
ZN Performance (OH) www.znperformance.com RX7 and RX8's performance and parts. 3488 Millikin Court Columbus Ohio 43228 614-264-9588
Old 03-09-2015, 03:49 PM   #1
zayrx7
zayrx7 is on a distinguished road
Our ligthen rotors
Here is a pic of our lighten and balance rotor going in one of a built semi-port motor
zayrx7 is offline   Reply With Quote
Old 03-09-2015, 04:07 PM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
How much weight did you remove? It looks like they were just barely "lightened" for balancing purposes..
Maybe post up data for before/after of both the lightening and balancing?
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-09-2015, 05:13 PM   #3
zayrx7
there's more weight removed on the face, didn't take a pic
Old 03-09-2015, 04:11 PM   #4
What series rotor?
Old 03-09-2015, 05:12 PM   #5
zayrx7
What series rotor?
fd rotor C
Old 03-09-2015, 05:27 PM   #6
zayrx7
it's about 70 thousand taken off, not that much in lower the compression, we are going to run 40 plus pound of boost on this motor with E85
Old 03-09-2015, 05:56 PM   #7
RICE RACING
Don Mega
RICE RACING's Avatar
sounds like you need the best apex seals...........
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-09-2015, 05:59 PM   #8
zayrx7
For sure in my next built
Old 03-10-2015, 01:53 AM   #9
chibikougan
chibikougan's Avatar
Not to be a dick or trash on you at all. Genuine concern.
Now isn't where you took all that material from going to interfere with engine operation?
Is that lowering compression? How much?
Anyone else any thoughts on that?
At dead center the chamber splits into 2 and forces the fuel air mixture through the exclusion to be ignited no? Would doing away with the exclusion ignite leading and trailing at once?
Also can it come away from the shaft like that?
Old 04-26-2015, 08:41 PM   #10
RICE RACING
Don Mega
pest exterminated
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-27-2015, 05:21 AM   #11
RICE RACING
Don Mega
Originally Posted by metal seals View Post
ting tong tan
chinese rice pan
you keep telling us Kev SCR's and snap crackle pop are made, good luck to you man, sounds like you will need it HAHAHAHA
But Kev told me it was India cause he could buy razor blade side seals there that are 0.5mm and they tilt real good in the rotors chopin up side plates in under 400km......... Just ask Shane Jones who had to throw his SCR eqquipped motor into the garbage bin
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-27-2015, 06:48 AM   #12
RICE RACING
Don Mega
disgraceful
Yes your boyfriends products are! you should be ashamed promoting them at every opportunity especially when you knew at the same time your shit products were and still are raping peoples hard earned money, and you have the nerv to come here and slander me for only speaking the truth about the garbage kev has done to people.
you are a skid mark on the bed sheet of the rotary world.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-10-2015, 08:04 AM   #13
Slides
Slides is on a distinguished road
You realise the tub in a standard rotor joins the two ignition points with a far larger/better flame path than any face machining ever will right? Any difference around the sides of the tub is inconsequential in terms of flame path vs the tub itself.
Slides is offline   Reply With Quote
Old 03-10-2015, 09:05 AM   #14
My concern is taking the weaker of the rotor series and removing material close to where they're very thin and like to dent anyway.
Old 03-10-2015, 11:59 AM   #15
zayrx7
No concerns on this method! it was done by 2 well know shops
