Old 01-12-2011, 09:45 PM   #1
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
Just ordered some wheels, and would like to clarify tire size before ordering.
I ordered a set of wheels.
Front 18x8 +38
Rear 18x9 +38
My car has tokico blues and eibach springs (1" drop).
My question is will 225/40/18 (front), and 245/40/18 (rear) work without fender rolling, crazy camber, and still clear my springs?
I would like to get as much tire as I can without tons of modification.
I'm sorry for asking as I know wheel fitment has been covered and covered, I am still working on the 200+ post thread on the Evil Forum.
Thanks,
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 01-13-2011, 12:06 AM   #2
Fronts are not going to fit.
You need like a 1/4" spacer up front to clear the inside (suspension).
Old 01-13-2011, 12:28 AM   #3
LunchboxCritter
Simply Rotarded
Is a 215/40/18 a better choice, or a 5mm spacer?
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 01-13-2011, 01:48 AM   #4
Narrower tires are not going to work.
The rim lip is going to hit the bottom spring perch of the shock.
~6mm = ~1/4", so the 5mm spacer should work.
Old 01-13-2011, 02:03 AM   #5
LunchboxCritter
Simply Rotarded
Okay thank you. I'll order some spacers as well.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 01-13-2011, 12:16 PM   #6
LunchboxCritter
Simply Rotarded
One more question. Would a 255/35/18 tire fit better in the rear? 18x9 +38mm
The 245/40/18 tires are a little easier on the wallet, but I'm willing to pay the difference if the tires will fit more flush with the lip of the wheel and still clear.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
