Old 01-15-2010, 02:06 PM   #811
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Mag converter off of an ABS sensor
If the trans works well in the FC, I'll be doing the same thing with the FD. It's not an extra gear, it tightens up all the gears. You do loose some OD though. Im using the RX8 gear set, .84 OD FWIW. I think the ratio's will be spot on though. Especially the 1-2 & 2-3 shift.
My trans is jacked. The guy that rebuilt it did a shit job and i spent way to much on it. I'll watch for updats.
Old 01-16-2010, 01:08 AM   #812
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
You would need to
change the clutch, maybe the flywheel,
starter
and worst off, modify the PPF as the tailshaft housing is most likely very different.
Speed sensors are another thing to worry about.
Yeah Jay, forgot to mention that, there's no speed sensor on this tranny. You'd need to use an aftermkt speedo with a programable hall effect sensor..........
Me, I got my MoTeC
I Gots a Platinum Sport 1000, it is capable
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
