frustrated!
Rep Power: 17 ![]() |
I might do straight water since my garage is heated....just hope my heater never goes tits up. I will never have the FC out in the winter or cold fall mornings.
How much of a mixture would one need to prevent freezing but not required to do a major up-tune.
Same pig, new soul
#2 | |
Don Mega
No freezing No retune Best power Highest cooling to economy of fluid use *important aspect* Flow rates you need are posted in the other links I gave you. Tested to 17.5psi with T04Z and 13B-REW engine (higher compression than you).
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 02-16-2010 at 06:45 PM. Reason: extra detail |
#3 | |
How are you doing brother? So you are now using a 50/50 mix with your pre-turbo setup? |
