Old 12-03-2010, 04:37 PM   #1
JustJeff
JustJeff's Avatar
Originally Posted by RX200013B View Post
just make sure it's high enough for the gravity feed
How much higher than the OMP does the tank need to be to ensure proper gravity feed? Does the RA adapter call out a spec for that?
I was thinking of getting the RA OMP adapter for my '89T2, and since my subzero start assist system is disabled, the thought was to use the subzero tank in its stock location to become the premix tank. Not sure how practical that would be, as it doesn't have much capacity and would be a bit awkward to fill, given its location.
I haven't seen anything about how high it needs to be for gravity feed. Educated guess tells me that the less vertical the tubing/hose is the less affect gravity will have. Following that same logic I'm also guessing that the reservoir would need to be higher than if it were a direct vertical drop.
TTT has his mounted where the air pump bracket would be..I forget if he has an RE or an REW. I'm gonna guess at most that's less than a foot. BUT that is also a direct drop down to the MOP. Tubing that is travelling a more horizontal path I'm guessing would need to be higher.
Old 12-03-2010, 07:43 PM   #2
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I believe he has the RE, with the REW turbos....
just checked his sig... above information is correct
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
