Old 02-26-2011, 09:50 AM   #11
Hey TTT, are you running some kinda funky split on idle?
I've never had problems with my Crane Cams HI-6 on stock leadings on an FC - trailings are stock.
My experience supports RR's comments, spot on.
I was running that funky "reverse split" ignition timing once, and that's when the idle was not stable.
Sure, you can run slightly leaner on reverse split, but it wasn't worth the hassle IMO.
Hey Ted, nope, running a basae timing of 5* that ramps up REALLY quick to 25*. The 5* is in the 1000-1100 range, and 35-55 kpa. The split was a striaght 10* across the board. It since changed after my trip to CA where a buddy blended his cruise map with my map. So now it's 5* @ idle (I haven't noticed a difference) 0* by 1500 and -4* in the cruise ranges. Helped the mpg as I was able to lean the hell out of the fuel map and run 1.05L while cruising. Brought EGT's down as well which is what we were trying to do.
With the ECU you were using, were you not able to adjust the split based on load or rpms? Was it constant?
