| Introduce yourself!! Tell me something about you and your history with rotary.. |
#1 | |
From what you are saying I would lean more towards you are not getting fuel. You can easily check this by removing spark plugs and turning the car over to see if there is any fuel mist. Make sure the plug wires are not connected. When done with that pull the EGI fuse and crank it over to unflood the engine if indeed you do have fuel. If there is no fuel test the EGI fuse. Make sure the fuel feed line" The on with the fuel filter" is connected to the lower and or primary fuel rail and the line from the secondary goes back to the hardline for the tank.
![]() Here there is a link to the Factory Service Manual. http://rotarycarclub.com/rotary_foru...ead.php?t=1790 Start there and let me know what you got. Also check back often and give me your input so I can effectively help you with this problem.
#2 | |
Also did you fix the issue on why it overheated? Was it the coolant seals? Flush radiator and put in proper thermostat? Pressure Cap?
When filling the S4 radiator you have to make sure and fill from the radiator then the water pump housing to make sure you get the thermostat to open when it reaches operating temp. You also may need to burp the system to get all air out.
