Old 05-28-2011, 08:58 PM   #2
Garfinkles Motor Works
Not enough info to give you a good guess .Change all the spark plugs and see if they are sparking before you install them. If they are, check to see if the fuel pump is working,check pressure output .If that is good check the compression .
mazda, problem, rx7, start
