#11 | |
A proper fix would be to reweld the aluminum and machine it down to tolerance. Unforunately, that labor intensive and requires special machinery to do properly (or expensive). ![]() Your rotor housings look like you use some type of sealant on the o-rings? I don't like to use RTV types of sealant on those o-rings, but it's the only option you've got outside of the more expensive option mentioned above. Luckily, it's on the outer o-ring, so the stress is not as bad versus the inner o-rings; you don' t have to worry about the inner combustion chambers! -Ted |
