Old 03-25-2013, 04:34 PM   #2
mazpower
Rawr Bearclaw
mazpower's Avatar
Find the diagnostic connector under the hood.
IIRC, you run a test wire from the fuel pump pin to ground. If you look on the underside of the cap for the connector, you'll see abbreviations for the pins. Fuel pump is FP, ground is GND. Make sure the ignition is turned on otherwise the fuel pump relay will not power the pump.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
