Old 04-09-2013, 03:56 PM   #11
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
That's what I figured. I've convinced myself the booster push rod position changes slightly when vacuum is applied so there would have to be some kind of initial clearance. That's the only way I can justify why the FSM says to check everything while under vacuum. I guess I'll measured the clearance on my stock booster and MC and start with that.
I worried about that at first as well. I suppose you could always use a vacuum pump to put the booster under vacuum before fitting, if you really wanted to. I got lazy and just fitted it straight up with no vacuum. I figured I'd give it a try and see if it needed more adjustment after it was running. Doesn't seem to.
GySgtFrank is offline
