ok timing is a degree off, still running just a tad rich, had to back it off on fuel. then i noticed my floats are also a wee bit out of alignment, one starts putting a bit more fuel than the other, not much but i think that will effect things. so when the weather is good enough I'll try to get that fixed. the new exhaust kit helped it a lot. The old muffler had clogged on a broken baffle restricting the flow. at that the car sounds throaty, deep rumble at idle, happy i went with the apex stainless steel set up.
I was using 10w30 for a while and it was smoking quite a bit. I switched back to the 20w50 it smoked a whole lot less. Maybe worth a try if you haven't yet.
