Old 01-28-2015, 08:06 AM   #16
project86
Can't.Make.Up.My.Mind.
project86's Avatar
^Go with this, and a few other suspension bits you'll be super happy. I use my FC the same as you, and my setup started with the KYB AGX's. At the same time I put those in, I installed a set of Racing Beat springs, and later on replaced most of the stock bushings with the Energy Suspension polyurethane replacements (i.e, stabilizer bar bushings, front/rear control arms, etc.). Also added the Racing Beat "DTSS eliminator" bushings, because it felt like the stock DTSS bushings were worn out, and made the rear end handle unpredictably at the limits.
I'm still on stock wheels & tire sizes, and am very happy with this setup.
So... this is where i might sound silly....... but i want the to be able to make the car as low as I feel like. Im not one of the "hella flush" fan boys or anything but i do like to aggressive look of a low FC and I'm not planning on running stock size/offset wheels. I am about to replace all the suspension bushings with the same kit and getting the rear toe steer eliminator bushings.
Would you mind posting some pictures of what your car looks like with your set up?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
