Old 04-06-2016, 08:29 AM   #1
hybrid G
hybrid G is on a distinguished road
You are correct here, its truly the best way, true tried and tested.
But I want to work with what I have now..... no track days this yr.
low on $$$
"BEST" requires:
1) Aftermarket bumper (or mod stock front bumper) for larger holes in bottom corners
2) 2 oil coolers - left and right
3) Required plumbing to make it all work
hybrid G is offline   Reply With Quote
Old 04-06-2016, 12:18 PM   #2
low on $$$
The car is not supposed to be getting that hot (on oil temps) on the street...
Aftermarket oil temp gauge?
Can you verify the temps?
If your oil temps are indeed overheating on the street, something else is drastically wrong...
Do you still have an oil thermostat on the system like stock?
The stock oil cooler should have no problem dealing with anything you throw at it on the street, unless you don't drive under 4kRPM's...
