#1 | |
Rep Power: 20 ![]() |
Silica is glass (or more commonly known as: sand or silicon dioxide). I chose that media as the insulation because it can be small and remove about 99% of the air that would be in the chamber (since the silica particulate is so small). Thermal expansion shouldn't matter much if at all because the particulate itself is so small. When the chamber volume expands the silica will move to compensate, when the chamber volume decreases the silica *should* be able to move to compensate. http://en.wikipedia.org/wiki/Silica Another alternative would be Aerogel. It is mostly composed of air which makes it tremendously light. It also has an increased strength compared to other similar materials of equal dimensions. The real benefit is that they are wonderful insulators. This is the stuff that astronauts have in their suits to protect them from solar radiation (the heat, not the gamma). The trouble is I do not know the thermal expansion rate nor any of it's physical properties. http://en.wikipedia.org/wiki/Aerogel What I would find interesting and I think a little beyond anyone's skill on this forum would be to use thermoelectric coolers to cool the chamber wall and dissipate the heat directly into the insulation that holds them there. Granted you'd need to run wires and find a way to protect them from being melted/fried (probably have to encase them in the insulating material itself). Beyond that you should see a decrease in temperatures without increase in coolant temps (though this is not something for nothing). The trouble is as the heat increases and the thermoelectric device attempts to cool it, the more current will be drawn until either the wires burn up or the ceramic breaks apart. But it's interesting to consider. http://en.wikipedia.org/wiki/Thermoelectric_cooling http://www.fujitaka.com/pub/peltier/...FRJM5Qodnjbf9A
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 06-26-2009 at 09:52 AM. |
I am not going to mess with stuff that is basically very small tiny bits of glass.
I've messed with aerogel, but only with speakers...I'll leave that stuff with transducers. Peltier devices are notoriously inefficient devices. By the time you create enough cold to counteract the heat, you've produced enough (or not enough?) current on the order of significant horsepower. So all that did was load the engine down or blow your alternator? -Ted |
#3 | |
As for the silica, I don't think it would cause any problems unless the metal deteriorated enough to cause them direct access to the combustion chamber or leak into the oil reserves (which I don't think they would at all unless there was a catastrophic failure). Combining the silica with a metal based epoxy or resin would eliminate any fear that a rouge silica particulate would find its way into a place it shouldn't be. The only other option would be to fill the chamber with insulation material (fiber glass) and some aluminum.
