Old 02-26-2014, 11:41 AM   #166
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Love meshies.... Timeless look and would compliment the old skool well.
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 02-26-2014, 12:27 PM   #167
Stock vert wheels with 205s or 215s. Cheap wheels, cheap tires, look good, Mazda centers, yes they are 6.5" but you have no need for more tire at this time, can easily borrow Curby's for test fit. Doesn't get cheaper or better than that.
Old 02-26-2014, 12:38 PM   #168
I would consider looking into some old school domestic wheels as a vintage mustang pattern would work. Just my worthless 2 cents.
Old 02-26-2014, 01:10 PM   #169
Mayba something like these:
http://www.customwheelsexpress.com/c...ls-p-1737.html
Old 02-26-2014, 01:53 PM   #170
Those wheels are HEAVY!
Old 02-26-2014, 02:27 PM   #171
True, but you get the general idea. Besides, this isnt a race car lol
Old 02-26-2014, 03:28 PM   #172
Indeed. However, to make a slower car faster (quicker), lower the weight. Considering that the unsprung weight of the wheels is the greatest to overcome, I would rather have lighter than heavier!!!
Old 03-12-2014, 09:43 AM   #173
More stuff happening. Pretty much all taken apart, waiting on parts!
What is this malarkey?
Looking pretty.
Here is what is left, and what is happening with the beast.
The GSL-SE stuff is going to have to wait until summer/fall to be fabbed/installed. The front struts and rear axle need to be completely rebuilt, and I don't have the funds for that right now. Since I already rebuilt the Cosmo rear end last fall, I figured fuck it, I'll just run the Cosmo stuff.
Fun fact, the Cosmo rotors are bigger than the GSL-SE stuff....
The front is all apart, waiting on ball joints, sway links, and brake pads to show up. Trans is out and getting resealed. New Exedy clutch is here.
One issue that I found yesterday....the horror of fuel that sat in a tank for 15 years....
Old 03-12-2014, 11:38 AM   #174
Johnny_K
Johnny_K is on a distinguished road
Pics of rebuild.
Rotor cleaned and springs labeled
Permatex going on prior to Atkins housing o ring
Carefully installing o ring
Lubing up the rotor in preparation for the seals
Spring installed followed by the side seal
Rotor on rear housing
Rotor lubed for eshaft and corner seals and springs going in
Followed by the eshaft
Center iron going on
2nd rotor on, inspecting placement of seals
Front iron going on
How we ended the night
Johnny_K is offline   Reply With Quote
Old 03-13-2014, 03:58 PM   #175
jacobcartmill
Originally Posted by FerociousP View Post
(this assumes you have a center iron with inj bosses, which you'll prob have by the time you swap the bad motor out.)
Who said this motor was bad?
just an assumption. prove me wrong!
Also, when I tore apart the engine I was a little concerned.
Painted before rebuild.
so this is the engine that adler was messing with last weekend at charles'. the housings looked perfect!
so was it pulled, disassembled, cleaned, painted, and put it back together with the original hard seals? why all that work if the engine was good?
not hating, just curious. edit: i'm awaiting an update here with this thing running.
Old 03-13-2014, 04:07 PM   #176
Those housings did look great. I wonder how much the PO paid for them when the engine was first rebuilt...
Old 03-13-2014, 04:10 PM   #177
Two reasons why it was pulled.
1). It sat for 15 years (with periodic oil squirt and turns) so even though it had relatively few miles on it, I was concerned the oil control rings would be toast, and they were.
2) Charles and Adler are good men. I'll leave it at that.
Old 03-13-2014, 04:12 PM   #178
I used to have the receipt.
$837 for the rebuild in 1988 money.
EDIT: Online inflation calculator says it would cost $1655.01 in 2014 money.
Old 03-13-2014, 04:25 PM   #179
Wow for 15 years of sitting thats pretty good.
Old 03-13-2014, 04:29 PM   #180
jacobcartmill
DJ, i will go to deal's gap if you get this thing running.
