Old 03-27-2014, 07:47 AM   #1
Can't believe you have had this for over 2 years.
Old 03-27-2014, 09:36 AM   #2
Good updates. Can't wait to see this thing driving.
Old 03-28-2014, 06:31 AM   #3
You and I both. Been working a lot lately, and the brake hose issue threw me a little off. Still waiting on that strut tool to be made!
Once the struts are done, here is the list to do in order:
Reinstall front struts
Install new front brake hoses and pads
Install new sway bar links
Install fuel tank
Install new fuel pump
Install new clutch slave and master cylinder
Install transmission
Install engine
Install radiator/oil cooler
Install new rad hoses and stuff
Bleed all the brake and clutch hydros
Fill differential with fluid
Fill transmission with fluid
Fill engine with oil
Fill engine/rad with coolant
Reinstall headlights, taillights, associated trim
Find and install a muffler (this one is roached)
Really, nothing there is hard, or time consuming. The 'hardest' part is probably all the trim installation.
The first week on April (6th-12th), with wife and kid will be out of town. I still have to work, but I will have more time to work on it. Also, Sundays are free, so I can get stuff done then as well.
If any of my local peeps want to help, feel free to text me.
Old 03-28-2014, 09:01 AM   #4
Next two weekends are completely full for me, and i'm not exactly local anymore with a 30-40min drive each way, but if it really comes down to the wire i'll come down to help later in April.
Old 03-28-2014, 08:51 AM   #5
I would lend a hand if I were closer.
Old 03-28-2014, 05:27 PM   #6
jacobcartmill
i would honestly help but i have FD problems at the moment. currently trying to fix my "riding dirty" status.
Old 03-29-2014, 11:42 AM   #7
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
SA hoses in the mail. Hope they work for ya.
Old 03-30-2014, 07:58 AM   #8
Big thanks Tim. They should work, one more piece of the puzzle, checked off.
Old 03-30-2014, 11:23 AM   #9
FC Zach
FC Zach's Avatar
If work wasn't so demanding and having us work 6-7 days a week I would help. Till then I'll periodically check your build here, good luck bud!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-31-2014, 08:19 AM   #10
reddozen
Gold Wheels FTW
reddozen's Avatar
Damn... I'm in Atlanta on business all that week, or I would be game. May be able to help that weekend the 12th/13th if it's not already done by then.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 03-31-2014, 08:31 PM   #11
Brake hoses arrived today. Big thanks to Tim. Not only are they new, but Mazda OEM!!
The strut tool is also fabbed and works perfect!
Old 04-01-2014, 07:09 AM   #12
t_g_farrell
Waffles - hmmm good
I figured you would appreciate the original bag they came in. Sorry they were
opened but I use them to very the SS ones I got as replacements.
Old 04-04-2014, 06:34 AM   #13
So, my wheels are delayed....again....probably won't have them until another week and a half.
Because of this, I have a question:
Would you risk running the engine on jackstands? I am going to need to break it in, with only a short amount of time to do it!!!! It isn't a bridge or any huge port, so it should be fine.....right?
Old 04-04-2014, 07:32 AM   #14
Only issue I see is the possible need to put some load on the engine... and that you'd have to sit there varying RPM for what? an hour? otherwise you are just idling and free-revving. I don't see how the port would matter. Also, you are reusing bearings right? That should shorten the time. If some have done it before then they can chime in. what sucks it putting a newly rebuilt carb on a refresh engine.
Break it in on the caravan, and change the oil once you get there!
Old 04-04-2014, 09:01 AM   #15
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Man this is a nail biter!! Paul is right break it in on the way. This goes for all mid-tenn folks.... I will have my tool box and trailer if anything happens to your cars I can pull it home you just have to drive my car:-)
03 Dodge Viper SRT-10 Vert
16 MB ML350
