Old 02-14-2011, 08:58 AM   #16
Judge Ito
Porting Master
Judge Ito is on a distinguished road
some wrong advice in this thread. do not torque pass 75ft pounds. use some lock tight and aim for .0025 end play, this is in inches. hope you have a good dial indicator.
Judge Ito is offline   Reply With Quote
Old 02-14-2011, 09:26 AM   #17
The FSM states, 80-98 ft/lbs.
Old 02-14-2011, 10:36 AM   #18
FC Zach
FC Zach's Avatar
Update
I got it all torqued down, I did use LocTite and double checked end play afterwards. I had been reading the gauge incorrectly and triple checked to be sure. I had a reading of 0.039mm with a 8.00mm spacer. The S and T spacers I had ordered from Atkins are no longer needed, I'll just hold on to them for the future, someone may need them.
So far so good, the engine is running smooth and started right up on first crank after priming. Starts up hot, no leaks, and lookin good. Already put 260 miles on her and I'm keeping a close eye on things for the next few hundred miles. All in all I'm proud of the turn out and appreciate everyone input, Thanks!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
