Old 07-22-2011, 08:37 PM   #31
That sucks Alex. I hope it get it going again soon. That way you can have more fun before winter sets in at least.
I actually had a dream about this car last week. I don't know if you were driving or not, but it was in a race and destroying everything else on the course, passing every other car up a hill and then jumping the hill haha. Weird.
im deploying in october, so i wont be driving til after im back im certain. That said i aquired the bellhousing from a B2200 which will allow the rx7, miata transmission i have to attach. directly to the FE3. Gotta love M type interchangablity...
Hopefully ill be driving to portland this weekend coming up to grab the engine. Then i can engineer!
Old 07-24-2011, 03:10 AM   #32
Yeah I'm deploying soon too. Where are you going? Send me a text.
Old 07-26-2011, 09:33 AM   #33
car is now in the garage and being taken apart. I have the FC subframe with the correct hubs, but no calipers. Going back to the pull a part for some FC parts i spied. For the time being, i am maintaining the smaller 4x114.3 back brakes to not only clear the wheels i have (FC 4 pistons are like subarus, some 15" wheels dont fit) and because i have a 4x114.3 rear. Not having different lug patterns for obvious reasons.
also, i am using the GSLSE rear axles and brakes i have. Nice 4x114.3 lug pattern (regular rx7 is 4x110) and uses vented rear rotors. So essentially, i have most of what i need. At this point just a matter of the engine. Seems as thought the 1.8 BP motor is going to be the way im going. The FE3 isn't panning out too well (granted i found the right bellhousing in my garage...) but im not driving that far for it, in addition to the added work of making...well work. Plus the miata was designed for high lateral G oiling and is dimensionally superior.
So of the other parts will be taken off the "rallyx7" project. Mostly because i wasnt able to get a title and there are cleaner cars out there. I might even take the good non sunroof of it to replace my current bondo leak fest roof.
Old 07-29-2011, 09:46 AM   #34
will i am trying to get some pictures up, i did find some information on my old engine so i can compare for myself (butt dyno). Anywho, the 12a, streetport with the 48 IDA made just about 130 wheel horsepower. This was with large amounts of dyno time as well from what i was told. Car ran pretty good with 130whp. I attribute that to 4.88 gears. But at anyrate, the miata BP will do that or more with not too much difficulty.
Old 07-29-2011, 11:43 AM   #35
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
A SP with an IDA and it only put down 130 to the wheels. It wasn't running
well at all IMHO. My stock port does 134 with the mods in my sig. I would
expect a SP to put down at least 10 or 20 more, like ~150 to the wheels.
And I know dynos vary and so on but really that doesn't seem as good if
there were large amounts of dyno time spent on it.
Shame your not sticking with the rotary but I understand the motivation.
Good luck with the build!
Old 07-30-2011, 12:46 AM   #36
perhaps sometime on a future car (im certain to stay with mazda, very good program for motorsports they have) and i might build myself another rotary. just not in the financial cards...
more progress today and last night. Due to the GSLSE axles being big spline, i had to change out my rear end entirely. Car had the small spline... At anyrate, i put it my reinforced GSLSE axle housing. Once i replace the out bearings for the axles, those and the brakes will be on as well.
Additionally, i have been working on the rear fender wheels. A combination of rust (oregon car) and wanting increase clearance lead me to cutting and grinding. I have done this same ordeal to three FBs now and am getting rather good at it. That said, rust makes thing harder. Rust repairs that have been done previously make it harder still. The pictures below are the rough in. trying to get the wheel well flush . Once i get the welding gas tank refilled i can start welding.
Old 07-31-2011, 11:20 PM   #37
Old 07-31-2011, 11:21 PM   #38
The remaining portions of the steering was removed today including the steering box and column. The stud that will hit the new subframe were removed and the frame pinch rails notched for clearances. The new steering column was pulled from the parts car as well. Was some progress. Hot as hell today too. Welding tank is getting refilled tomorrow so i can start the finishing the rear flares and the rear subframe studs.
Old 08-14-2011, 01:37 AM   #39
so now comes the question of "how do i mount this stupid engine." Its seems that frame rail mounts would only work on the passenger side. The Driver's side has the steering in the perfect place to not work. Pics of that are below. I am using the 2" sleeved bushing tube mount (is there a simple word for this??) A friend of mine savvy with machining made me some aluminum inserts to use will mocking the engine and welding. This is so the poly doesn't melt, obviously. Im probably going to build off the sub-frame.
Also, the cam sensor hits the firewall before the front of the oil is clear of the steering rack, to my preference. If i can move the sensor into cutaway into the firewall, then the engine's front can come down since the pan would clear. This would allow me an easy closing hood.
Anyway, here is what im working with...
Old 08-16-2011, 08:41 PM   #40
flares are done!
Old 08-23-2011, 10:57 PM   #41
more progress!
Engine bay was stitch welded as was most layers of metal touching it. Painted over that with tractor paint so i could get the fenders on. Seems as though some of the attachment points have been...rusted and had bolts broken off. Reminds me of home (ohio) anyway.... ill have put some screws into it to hold. But they are mostly on.
Also finished the rear structure welding and coated it all with truck bed liner. I just need two more weldable inserts and the rear mudflaps will be on as well. Engine will be going in soon i supposed. 13b engine i had laying around is the game plan. will be cheaper and i can reuse a lot of parts. Also better for me to learn on!
i also saved 10lbs via removal of the headlamps. also cleared some space and removed some wiring and relays.
Old 08-24-2011, 07:45 AM   #42
Fidelity101
Reliable Source
Fidelity101's Avatar
I haven't been on here in a while, NICE buy my friend! I gotta come chase you around now!
last weekends rallyX
why are you putting in a boinger?
My Rx-7 Vids
Old 08-24-2011, 03:41 PM   #43
I'm staying rotary now. I have a 13b for it now
Old 08-25-2011, 11:01 AM   #44
Fidelity101
Reliable Source
phew, thank god. Woulda had to steal it.
I like the diff cover... alot
My Rx-7 Vids
Old 10-11-2011, 03:58 PM   #45
Fidelity101
Reliable Source
http://bringatrailer.com/2010/08/17/...x-7-rally-car/
found this on one of my fav' site
My Rx-7 Vids
