Old 04-13-2008, 10:28 PM   #46
ACowden20
ACowden20's Avatar
ACowden20 is on a distinguished road
Another picture of Dan hard at work:
Actually, I have to thank Dan for allowing me to borrow some tools and floor space while pulling the head on my MR2 Turbo. What ever he says about me holding up his progress is wrong
ACowden20 is offline   Reply With Quote
Old 04-13-2008, 10:55 PM   #47
Chadwick
Chadwick's Avatar
Actually, I have to thank Dan for allowing me to borrow some tools and floor space while pulling the head on my MR2 Turbo. What ever he says about me holding up his progress is 100% correct,
Fixed that for you!
Dan
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Old 04-14-2008, 07:13 PM   #48
sbrian2
Rotary Wannabee
sbrian2's Avatar
sbrian2 is on a distinguished road
Hey, I just found where you can pull about 30 lbs from the car.
-Brian
'95 Mazda Miata R package
'90 Mazda Miata turbo
'06 Chevrolet Trailblazer SS
'01 BMW 325Ci
'91 Honda CRX hf
sbrian2 is offline   Reply With Quote
Old 04-14-2008, 11:10 PM   #49
Chadwick
Chadwick's Avatar
Take off one of the turbos?
05 Silverado Z71
08 Mini Cooper
Old 04-21-2008, 12:14 AM   #50
Chadwick
Chadwick's Avatar
Added a few more pictures of the motor installed and other misc. parts.
Dan
05 Silverado Z71
08 Mini Cooper
Old 04-21-2008, 02:08 AM   #51
Brent
Sua Sponte
Brent's Avatar
I was wondering if you had finished it. I just finished looking on the tr site to see if you raced but didn't see you. However, one of my soldiers that is here with me in Afghanistan apparently raced in Nashville yesterday according to the results on the website... lol.
Old 04-21-2008, 11:09 AM   #52
Chadwick
Chadwick's Avatar
Now that is a long haul to get back and race !
05 Silverado Z71
08 Mini Cooper
Old 04-27-2008, 11:13 PM   #53
fire85gslse
fire85gslse's Avatar
Dan, can't wait to see her on the track. Everything looking good. See ya Tuesday.
Chad
Old 04-27-2008, 11:18 PM   #54
Chadwick
Chadwick's Avatar
First and second post update with a bunch more pictures.
We started the car today and it is purring like a kitten but we did have a little drama getting there.
Yesterday we buttoned everything up and started to fill her with fluids. When she got about ¾ full of water a small leak was apparent. It looked to be coming from the coolant supply hose to the turbo. We took off the hose, inspected it and the fitting then re-clamped it. To our surprise it was leaking even worse. That is when we noticed the water was coming out of the fitting that is pressed into the water pump housing, not the hose. We had to tear everything back off the front of the motor and replace the housing. While Brian, Andrew and I worked on getting everything back together, Mike polished the crap out of my Greddy Elbow and intercooler .
With the water leak fixed Brian wired up the FJO injector driver and I wired up the Jacobs and we were ready to turn the key. Brian cranked her for about 6 seconds and she started to fire but he had already committed to releasing the key. He hit it again and she fired on the second crank. Right from the start she idled super smooth and only kicked out smoke for around 5 minutes. Andrew and I adjusted the fuel pressure and we let her get up to temp watching for any leaks the whole time. That is when we noticed a mist of what we thought was water coming from somewhere on the front of the engine. It was being slung by the belts and making a mist so it was really hard to tell where it was coming from. I had Brian kill the engine.
With the engine off it became obvious that it was not water but oil that was being slung and we could see right where it was coming from, the front bolt on the eccentric shaft. Brian and Andrew pulled the piping and intercooler and we removed the bolt to find the crush washer had shifted when it was torque down. I promptly threw the crush washer in the trash. Brian applied a layer of RTV to the bolt and we reinstalled it.
We installed all the plumping back and fired her up for the second time. Maybe 2 or 3 cranks and she fired right up, this time with no leaks. We let her run for about 30 minutes and check all the pressures and temps. She is pulling 16-18 of vacuum at idle which is great for having all new seals and running for less than an hour total.
We all seem to think she has a deeper tone then before with a little stronger pop to the exhaust pulses.
Hopefully we can get everything else button down this week and get her on the dyno next weekend.
Stay tuned,
Dan
05 Silverado Z71
08 Mini Cooper
Old 04-28-2008, 09:34 AM   #55
Brent
Sua Sponte
Brent's Avatar
are you using stock or 99spec turbo's? Man, I wish I was around to see it! You done anything with the carputer?
Old 04-28-2008, 11:44 AM   #56
sbrian2
Rotary Wannabee
sbrian2's Avatar
They are 99spec. It was a frustrating weekend at times, but the payoff was worth the trouble. I told Dan we couldn't go home this weekend until it was running, so we accomplished our goal.
-Brian
'01 BMW 325Ci
'91 Honda CRX hf
Old 04-29-2008, 10:32 PM   #57
ACowden20
ACowden20's Avatar
I think we all felt a little defeated after the water leak on Saturday. Well that and when we found I had "forgot" to hook up the fuel pump after I installed it a few months ago.
Old 04-29-2008, 10:52 PM   #58
fire85gslse
Dan, thanks for the help tonight. It was good to see you all.
Chad
Old 04-30-2008, 08:27 AM   #59
Garfinkles Motor Works
I just saw this thread ,with all that torque you will need a garfinkle engine torque brace and a garfinkle oil pan brace for sure . Have you seen the garfinkle belt idler ,it is as nice as yours .
Old 04-30-2008, 09:44 AM   #60
Chadwick
Chadwick's Avatar
As Brian said, yes to the 99's. Wish you were around too, we will have some fun when you get back state side. We are currently working on the inside wiring (wideband, Dual EGT, Datalogit and Carputer) so I should have an update in a couple of days. We were going to work on some of it last night but ran into a high idle issue and a sensor not working. Resolved both of those so it is back onto the wiring.
You didn't forget, you were just testing our diagnostic skills
Chad
No problem, stop by anytime, just stay away from my 99 bumper
Oil pan brace is already on and we should be installing the torque brace this weekend. Like everything else you make your airpump delete idler pulley is a work of art. We just took two different paths to achieve the same goal.
Dan
05 Silverado Z71
08 Mini Cooper
