Old 02-20-2013, 12:29 AM   #121
85turbo12a
nerd
85turbo12a's Avatar
85turbo12a is on a distinguished road
what i meant to say was..got to get the gears changed out, and put all the parts back on it, going in for alignment this weekend. might be able to get the gears changed out this week or next
85turbo12a is offline   Reply With Quote
Old 02-20-2013, 01:00 AM   #122
FC Zach
FC Zach's Avatar
Glad to hear everything is coming along since the setback, looking forward to seeing this beast at DGRR!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 02-20-2013, 06:39 AM   #123
^What he said. That's one hell of a build, can't wait to see it at DGRR, I'll try not to drool on it when I do
Old 02-20-2013, 09:19 AM   #124
Originally Posted by 85turbo12a View Post
right test drive revealed i still have a vibration at 70ish, though its different this time and i blame the shaft itself, its about 1/2" too short now as well as when i had the Ujoint replaced the guy at the shop said the tube is slightly egged, so tomorrow i get a new shaft made and go from there....it has approx 2 degrees of drop from trans to rear and about 2 degree down pinion, that is the best i can do.
4* shouldn't be too bad, unless the offset is really bad.
even a short driveshaft will cause wierd vibes. Had them in my FC, a few shims and spacers got rid of it in the troubleshooting phase, can't imagine how the shaft got egged but that as well as I'm sure you know will do it as well....
in other news....it will spin the tires about anytime you want...passing people at 70mph on the interstate whilst crabbing sideways has got to rustle a few jimmies.
when its finally tuned it will be undriveable...methinks...
DO WANT!!!!
car is making great power and drives real nice, the combo such as it is, is a great one, now time will tell if the T2 trans will live, but ill just be nice to it now, got the gears changed out and put the swaybar and tailpipe back on it, and get it ready for DGRR!!
Normally I would say the rear would be the weak link as the TII trans are good for some serious power, but 8.8 so I'm curious to see which explodes first.
FWIW we're creating a stock of TII and REW trans, rebuilt and cryo'ed, ready to abuse/
What he said.
I think you and MC (2gslse) need to have a chat about the RESpeed kit.... I'm still of the mind that a proper alignment will solve it though, MC
Congrats man! Can't wait to see this monster.... chat it up this year we must
Old 02-20-2013, 10:56 AM   #125
Archie
Archie is on a distinguished road
I rarely venture into build threads, or the performance side of the house anymore. However, your build is absolutely professional. I hope you reap everything that you have painstakingly sowed into this project. You deserve it.
Originally Posted by yzf-r1 View Post
Think I don't know any military vets, son? I know far more than you, and they do care about this issue, they find gays repulsive.
Originally Posted by Turbo II Rotor View Post
I too like the part where Mark tells a Vet he knows more vets than him.
Mark Strong: he's got "axiomatic" down.
Archie is offline   Reply With Quote
Old 02-20-2013, 08:40 PM   #126
85turbo12a
nerd
85turbo12a's Avatar
thanks guys, yes Titanium, due to space..and configuration issues my first plan in response to a trans failure will be a beefed up version, such as they are, then if that just wont cut it, ill do the dirty deed and adapt something like a T56 or R154, the r154 is a really tempting install, they are super strong and dirt cheap, and work well once rebuilt with aftermarket pieces.
the t56 would just be kick ass though, uber O/D and nearly bullet proof for the power im making.
anyway, as far as i am concerned unless i dont make it there due to environmental reasons, or unforseen mechanical failure ill just add to my already silly credit car bill and hit the mountains with vengence...and tender throttle inputs
worst part of the whole deal is im going to lose my speedo accuracy...so ill have to run the gps speedo for a while till i get used to converting my speedo in my head hehehe
i found no good solution to the Rmodel transmission speedo gear, so at some point i will probably buy one of those electric speedo drives and run a mag/speed sensor on the diff and then i can tune it exact.
Old 02-20-2013, 08:47 PM   #127
85turbo12a
nerd
85turbo12a's Avatar
as far as the REspeed kit...i will refrain from too much bashing on behalf of the REspeed and Grannies, but i had to re-engineer quite a bit of both companies work to make it right.
both companies shorted me a few pieces and assorted hardware, that locally actually proved difficult to get, ended up having to order stuff from a bolt house down the road and wait for it.
as far as operation of the REspeed set up...too soon to tell you since its not properly aligned yet, it seems to be ok, i put a 15:1 manual rack in it.
i dont want to say it has bump steer...because it tracks pretty straight, BUT it is rather abusive to the steering wheel and requires a firm hold on it when road is rutted
some of the problem there could be from me having to lower the rack down with offset bushings changing the angle of the tie rods slightly from the original geometry, but i had no choice.
one thing i am for certain, despite all the quarks it has or might have in time...it is 5000000000% better than that &^*&^^$$$$*&^$*^%$ draglink...
Old 02-20-2013, 09:46 PM   #128
Kewl... sounds great.... as for the CC bill.... Meh..... I have ways
For the speedo.... check out a co called advanced adapters or Speedometer solutions... I have used both of them in the past with great success... Speedometer solutions sells a piece that places a halleffect sensor where the cable once lived.... works wonders... loved it when I was using it.
Advanced Adapters will build gears to adapt different tire sizes and rear end ratios for the NP transfer cases, they may be able to help with a gear... and I know I've seen in the past a little gizmo, I think it was from them or Dakota Digital that wil alter the output shaft speed to get the speedo correct... works on the same principal as those steering quickners....
Old 02-21-2013, 11:49 PM   #129
85turbo12a
nerd
85turbo12a's Avatar
and now for some comparison shots....
here is the car with turbo 12a power
and here it is in TT v8 trim....muahahahha
Old 02-25-2013, 10:56 PM   #130
85turbo12a
nerd
85turbo12a's Avatar
i am having a steering vibe that seems to be common among ReSpeed rack victims, allow me to direct attention to this club thread
http://www.rx7club.com/1st-generatio...-cause-947816/
im not the only one, and my symptoms are the same....am now in the process of sorting this problem out..like i needed any more problems at this point...
so for anyone here that has this set up or worked on one, lets try to solve it, because its hugely annoying
Old 02-26-2013, 04:37 AM   #131
2gslse
That sounds like the same vibe I have in my car and it wasn't there before I did the rack and pinion swap I have checked and rechecked and found nothing wrong with mine either. when I did my swap I replaced everything in the front at 1 time, steering, 5 lug conversion, new shocks, coilovers,lower control arms etc... I am about to just pitch the R&P and just put my stock parts back on.
2006 VW TDI commuter
Old 02-26-2013, 08:02 AM   #132
I know when I drove a local's SA with the RE-Speed kit, I had a serious brown moment when the steering wheel started to shake like hell. The 2 bolts that secure the spindle to the LCA's had worked loose, somehow. Once tightened, it went away, but I know his has some other issues as well. Like for some reason, it is harder to turn left than right. Weird.
The FC subframe on his daughters car has no issues though
Old 02-26-2013, 08:41 AM   #133
2gslse
It is one of my upgrades that wasn't really needed but I thought would be a great improvement when I did it but I like the kit but don't love it. my complaints on it are the vibration of the wheel and at low speeds in parking lots the car fights itself when turning(ackerman issues) I talked to Brian about mine and if it doesn't get better soon I will be removing the R&P and putting my old steering back in.
Old 02-26-2013, 12:28 PM   #134
one320fc
one Apex @ a time
one320fc's Avatar
I was just thinking about this build and had a great idea! I think once you and MC get all the kinks out, what better thing to do than put two silver FBs against each other V8TT vs single turbo 13BRE On a more serious note I hope both of you can get things sorted out very impressive builds!
1983 Limited Edition SOLD
1977 Mazda REPU I will work on it one day I sware!!
1987 T2 um after the repu is done??
2013 Chrysler 200 DD
2009 Dodge Journey
94 Volvo 850 N/A The slowest car I have EVER owned!!!
Old 02-26-2013, 01:54 PM   #135
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Let me set up a tire dealership before you do this. I'll make money hand over fist. :giggity:
