Old 02-14-2010, 09:39 PM   #1
sen2two
KTEC
sen2two's Avatar
weber cfm flow rates
Heres some i found, not sure of the accuracy... but seem reliable.
Source: JayCee Ent./Perf.Tech- flowed on Superflow 600 @25" water
Weber 48mm IDA w/44 venturi-348cfm (per venturi)
Weber 51.5mm IDA w/47.5 venturi-395cfm (per venturi)
JayCee 62mm /55 venturi -633cfm (per venturi)
with 20" water
Holley 1150 Dominator (4 barrel) 1180cfm (est.) total
Weber 48mm IDA w/44 venturi-311cfm (per venturi)
Weber 51.5mm IDA w/47.5 venturi-353cfm (per venturi)
JayCee 62mm /55 venturi -565cfm (per venturi)
Source: Gene Berg Ent. no flow specs given
Weber 48mm IDA 40mm venturi-561 per carb
Weber 48mm IDA 42mm venturi-583 per carb
Source: CB Performance 1991 catalog- no flow specs or venturi sizes
I assume these numbers are @28" H2O per venturi
Dell'Orto 48mm DRLA 388.5cfm
Weber 48mm IDA 372.1cfm
Dell'Orto 45mm DRLA 329.3cfm
Weber 44mm IDF 292.3cfm
Dell'Orto 40mm DRLA 266.4cfm
Weber 40mm IDF 212.8cfm
Dell'Orto 36mm 205.8cfm
what I have:
What I had:
