Old 03-10-2009, 02:18 AM   #1
IH8DSM
IH8DSM's Avatar
85 gsl se wont start
Ok so i was driving to work the other day not driving it hard or anything and it just dies on me, tryed to start it and nothing it revs to a grand then dies like someone unplugs it or soemthing. So i take it over jfaplanets house and we do everything we can think of, swapped out ecu, maf, o2 sensor, its getting spark and fuel, its getting the plugs wet so the injectors are spraying the timing is dead on and nothing wrong with the distributor, checked the fusible links, fuel filter, ignitors, the thermostat core or whatever its called. This is a 85 gsl se fuel injected with a fresh rebuilt motor with not even a thousand miles on it.
Like i said ill start it itll rev up to a grand and then just shut off, sorry for the long read but were running out of ideas, if anyone has any shout em out cause if i can't get it running again i might be in one of charles rent a rotarys (red fc vert)
Old 03-10-2009, 08:12 AM   #2
Did you check the intake tube for cracks? Massive vacuum leak?
Old 03-10-2009, 10:11 AM   #3
IH8DSM
IH8DSM's Avatar
i looked when we swapped out the mafs and didn't see any cracks or loses vacuum hoses. its the weirdest thing it ran fine, great even and just died and now it won't even start don't understand it
Old 03-10-2009, 10:42 AM   #4
Fuel pressure? Just because the plugs are wet does not meant the pump can maintain the needed PSI to keep the engine running.
Old 03-11-2009, 12:11 AM   #5
IH8DSM
IH8DSM's Avatar
its getting almost 40 psi, the plugs being wet i was just saying its getting into the chamber.
Old 03-12-2009, 05:43 PM   #6
fire85gslse
fire85gslse's Avatar
Try vacuums, also try putting jumper cables on the ground terminal on the battery and the other side on the frame, then try motor? Maybe you lost a ground and the ecu is not getting proper voltage.
Check pin out on ECU to see if your getting proper voltage.
When it revs can you hold the gas and it stay running?
If not check exhaust. Maybe its plugged up tight!
Hurry up and figure it out before it gets towed off.....
Last effort - Try bolting a carb up to it and see it it will run.
Old 03-14-2009, 01:42 AM   #7
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Also check your brake booster hoses. Is there power to the distributor with ignition on? I had one come in once that had an ignition switch go bad. Uncommon when these guys were younger but they are getting a bit long in the tooth now.
Exactly what were you doing when it died? Notice anything just before it stopped?
Old 03-14-2009, 07:17 AM   #8
fire85gslse
it is the same problem that I had with my SE when I was trying to put the SE lower intake on my S4 block. There was something there creating a vacuum leak and well I had to put the S4 lower back on because I could not get it after 3-4 tries. So I still say Vacuum but it could be power. Have you checked the pin voltage at the ECU yet?
I tried to call you and charles with no luck. Even texted you!
Old 03-16-2009, 12:47 AM   #9
IH8DSM
IH8DSM's Avatar
ignition switch is good we checked that and it was running like a top no weird noises, was driving normal like 2 grand in 5th gear doing about 40-45 some where in there not revving high or anything and it just died.
we did the jumper cables no difference, when it first died id be able to start it rev to a grand then just die now it wont even do that it just cranks. We're gonna try to check the exhaust this week and i still need to find the pin out
yea we've been busy working, well charles has ive been supporting miller lite and such.
Old 03-16-2009, 07:04 PM   #10
2gslse
Check the trailing ignition it also triggers the fuel pump to run also make sure all the wires on the trailing coil are clean and tight one of the spade type is the one for fuel pump.
Old 03-19-2009, 02:22 PM   #11
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Sounds electrical to just stop with no other symptoms.
Water temp sensor or connector, I have seen harness failure right behind the connector, internal, the insulation looked fine.
Oscillator and connector in front of the battery?
At this stage with the plugs fouling, you have tried a new set of NGK’s I’m sure.
Something to try with the fuel system, try clamping the fuel line off. I use a pair of those
small needle nose vise grips with fuel line on the jaws. Crank and see if it fires. If it does then open up the grips just a tad to be able to let through a little fuel. It may take a few tries to get it right. I perfected this procedure in dealing with the FC. If this works it can indicate an issue with the regulator and or damper. Sometimes it clears out injectors.
If you have been doing a lot of trying the exhaust can load up with fuel, disconnecting the exhaust from the manifold will bypass it for testing.
You might want to check wiring and signals for the air flow meter and control unit.
Old 03-28-2009, 01:35 AM   #12
IH8DSM
IH8DSM's Avatar
ended up swapping out the fuel injection for a carb, started on the first crank, so im tired of messing with it need my dd back again so im ordering a carb set up for it. Should be on and tuned before the dragon. Thanks everyone for there help the blue cars gonna make it to the dragon if i have to tow it haha
Old 03-28-2009, 05:24 AM   #13
fire85gslse
You also need to open her up on Road Atlanta in July. No steep cliffs
to fall off and stupid butts to run into you.
Sorry to hear the FI is gone. it probally had to do with ignition or fuel.
Old 03-28-2009, 10:12 AM   #14
IH8DSM
IH8DSM's Avatar
were thinking fuel, and the more charles talked about carb the more fun it sounds haha
