Old 08-19-2009, 05:33 PM   #1
Zenki7
Zenki7 is on a distinguished road
Who REALLY knows?
Grabbed up some Block off plates put those all on.
Heres my question the hard vac lines that have the solenoids on them do those need to go back on? and also it seems there are alot of other parts that dont seem like I need ot put them on?
There is a pressure sensor is connected to the Air control Valve but I eliminated that so of course I cant put that back on.....
Air bypass valve and check valve.....
Air bypass Solenoid Valve I mean is there really anything that NEEDS to go back on?
What do you do about the sensors that you plug in from the harness too btw? Doesnt the ecu show a check engine light all the time??? Whats the way around this aspect of things?
This is a picture of the hard lines Im talking about do I need these at all
Of course I need the pulsation dampner and pressure regulator and see hoses run to them but cant I just run hoses straight to them without having to use the WHOLE thing? this way it will eliminate some crap in the bay???
Zenki7 is offline   Reply With Quote
Old 08-19-2009, 06:09 PM   #2
NoDOHC
NoDOHC's Avatar
There are writeups on emissions removal, look at them.
I would answer your question here, but it completely depends on what functionality you intend to keep.
Old 08-19-2009, 06:52 PM   #3
Zenki7
I used Kevins write up on Emissions removal. But what Im asking is not covered. I dont really intend on keeping any emissions items that are not needed. I really want to remove everything I dont need. The only thing that crosses over into emissions dept that I am keeping is my OMP. I dont want to have to premix.... other than that if the car can run without it I want it gone.
Maybe I will just continue to put things together and figure it all out as I go, help before hand would have been a lot easier though...
Old 08-19-2009, 07:04 PM   #4
need RX7
Clean S4 Nutswinger
need RX7's Avatar
You can get rid of the whole vacuum rack and run lines straight to the fuel rails.
Old 08-19-2009, 07:06 PM   #5
Zenki7
ok awesome so there is nothing else Im not seeing or thinking of that is running off that rack perfect!
EXACTLY what I was looking for!
and what about in the way of sensor etc that plug into the engine harness if those items arent there wont the ecu read bad???
Old 08-20-2009, 06:26 AM   #6
SecondGenPat
Start a Revolution
SecondGenPat's Avatar
SecondGenPat is on a distinguished road
from your name I'm guessing you have an s4
so, the s4 computer could not care less if the emission plugs are connected to the solenoids or air. The primitive pcm does not have any feedback sensors to let the pcm know that a requested function actually happened, also the pcm does not have any amperage monitoring circuits for the solenoids to monitor their operation.
-Pat
That to secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, — That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
-The United Stated Declaration of Independence
SecondGenPat is offline   Reply With Quote
Old 08-20-2009, 09:32 AM   #7
Zenki7
Thank you Pat looks like Im actually getting some help! Thanks alot guys, if anyone else has any input or anything feel free to chime in !
