Old 04-27-2009, 09:30 AM   #1
My5ABaby
My5ABaby's Avatar
Dragging brakes
Is it normal to hear the front pads dragging while the front end is in the air?
Also, what would cause the pistons in both of my back brakes to not retract fully and drag?
Community Service Manual
RotorWiki
Old 04-27-2009, 10:02 AM   #2
Depends. It's not going to behave as though it doesn't have brakes on it. It will drag a little bit, but should be very easy to move by hand. The drag coefficient of the brakes are not big enough to slow the car while moving.
That would probably be the "ratcheting" ability of the rear brakes. As the rear pads get lower, the parking brake incrementally adds additional pressure (not really pressure, but height to the piston) to allow the emergency break to function properly.
In other words if you can turn the wheels by hand, you're fine. If they're dragging more than that you're not fine.
Old 04-27-2009, 10:56 AM   #3
My5ABaby
My5ABaby's Avatar
The left right might not be that bad, but it didn't spin that well when in the air. However, the right rear was heating up the rotor substantially while driving.
RotorWiki
Old 04-27-2009, 11:01 AM   #4
Then something is wrong with the caliper to the proportioning valve. Check to make sure you have even wear on the rear pad, maybe even double check the caliper for proper action. Remember you'll have to screw-in/rotate the piston to have it retract. Also double check to make sure you have all the springs installed, etc.
I'm just guessing but what may have happened is that the spring got lost some where and when you pulled the e-brake the brakes were never reset by the force of the spring. Just a thought and probably not what actually happened.
Old 04-27-2009, 11:18 AM   #5
My5ABaby
My5ABaby's Avatar
Springs are there. I manually retracted the piston and it didn't drag, but after hitting the brakes once it started dragging again.
RotorWiki
Old 04-27-2009, 11:35 AM   #6
Then it's definitely applying too much pressure and retaining that pressure. Try bleeding out your brakes, if that doesn't work you may need to rebuild that caliper.
Old 04-27-2009, 12:05 PM   #7
My5ABaby
My5ABaby's Avatar
I've bled them a couple times so that shouldn't be a problem. I'm getting replacement calipers/rotors (since they're currently 23 years old) so hopefully that will help. Thanks for the help.
RotorWiki
Old 04-27-2009, 12:26 PM   #8
Hope it is your caliper. If you're still having problems start checking your proportioning valves.
Old 04-27-2009, 12:30 PM   #9
My5ABaby
My5ABaby's Avatar
When I figure out what that is, I'll check it.
RotorWiki
Old 04-27-2009, 12:41 PM   #10
http://www.rotorwiki.com/images/6/6c/11_braking.pdf
25/67 gives you info on how to check it and what it is.
Old 04-27-2009, 10:48 PM   #11
Shadow24v
Shadow24v is on a distinguished road
not to hi-jack but my FC has a similar issue, it doesn't seem to affect driving at the moment, but the fronts are hard to turn by hand when its jacked up. thats AFTER a 600 mile trip on a tow dolly (rear end on the dolly, fronts rolling). I might be looking into remaned calipers if it doesn't clear up
Shadow24v is offline   Reply With Quote
