Old 05-30-2009, 02:13 PM   #1
7fire3
7fire3's Avatar
7fire3 is on a distinguished road
Ok, all my Q's in this thread
I've made to many threads asking single Q's, so I'm just going to lump it all in here.
Question
1. Why does my car idle at 1500 RPM? but after it warms and drives for a while it wants to die or idle low. Is it a vacuum leak? Or something more serious?
2. What are things I should check first on the car?
3. The guy before me has a fuel line/pump switch. It's kinda ghetto rigged under the dash. Is there a better way to hook one up and have it work better?
7fire3 is offline   Reply With Quote
Old 06-01-2009, 09:29 PM   #2
7fire3
7fire3's Avatar
Old 06-01-2009, 11:01 PM   #3
Caim
Caim's Avatar
Caim is on a distinguished road
I am not going to go into the first one, just because i do not have time..
2. I would go about checking the compression first just to see where you stand. It always a good thing to know. And other then that what is done to the car so i know where to go with this.
3. I would go back to as close to stock as possible. But if you cant then i would end up wiring it up to a relay so that way it works when the key is on, and also it is the right way to do it.
Caim is offline   Reply With Quote
Old 06-01-2009, 11:28 PM   #4
7fire3
7fire3's Avatar
How much are these cars worth stock with low compression? If for some reason I do decide to sell it (Not that I will) but it's good to know.
Old 06-02-2009, 02:56 AM   #5
/\ $100. :d
Old 06-02-2009, 03:34 AM   #6
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Free if you drop it off at my house
But really, a bone stock series 4 n/a with low compression isn't worth that much. I bought my '86 base with a blown engine for $500. So maybe, going on the hope that the housings are still okay, maybe $700, if you're lucky?
Old 06-02-2009, 10:51 AM   #7
7fire3
7fire3's Avatar
I'm not saying my car does have low comp but only IF it does, and it's a TII 88 RX7 with 125k miles
Old 06-03-2009, 07:56 AM   #8
moremazda
shookmotorsports.com
moremazda is on a distinguished road
If that is 125k on the original motor than most likely the compression is lower than ideal. You really should start with a compression check.
Does it start right up or does it take a few cranks?
moremazda is offline   Reply With Quote
Old 06-03-2009, 11:50 AM   #9
1. could be a bad TPS, could be an intake leak
2. Things to check: Compression, leaks, fluids must be topped off, spark plugs must be clean, check fuel filter, Oil change......
3. If you can clean it up then do that but that switch only tells me the guy had flooding issues. If it works leave it alone....
These cars sell for 100-4500 depending on condition.
Old 06-03-2009, 08:04 PM   #10
7fire3
7fire3's Avatar
Usually it starts in around 1 crank, I'm sure the compression isn't like new but it seems to run and drive fine. The oil and coolant seem to be great and it never smokes. Just idles weird.
I am thinking it's the TPS now, I'm going to check around and make sure.
I'm going to run some rotella 15-40 or around that in it soon, the oil change in it now seems a little old
Also what I meant about the switch was where is a good place to put it?
Thx u all
