Old 02-09-2010, 09:12 PM   #1
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
gkarmadi is on a distinguished road
oil temp question
what's a good (healthy) oil temp reading during normal driving (cruise), stop & go traffic and on a "spriritted" driving when its taken from an oil pedestal??
I just hook one up (autometer) and needs to know what temp is good and what's overheating.
thanks.
86GXL
BSC streetport + TD07@13psi
gkarmadi is offline   Reply With Quote
Old 02-09-2010, 10:43 PM   #2
They should be pretty much inline with coolant temps. Anything below 160 is too cold in my eyes and anything above 220 is getting too warm, but nothing to panic about.
Old 02-09-2010, 11:07 PM   #3
Ender
rotors excite me
Ender's Avatar
That's about what I was thinking, but I was unsure and didn't want to talk out of my ass.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 02-09-2010, 11:59 PM   #4
I applaude you, seriosuly, no sarcasm at all.
Old 02-10-2010, 05:40 AM   #5
http://fc3spro.com/TECH/MODS/EL/GAUGES/otemp.htm
Old 02-10-2010, 08:07 AM   #6
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
Thank you all!!!
86GXL
Old 02-11-2010, 03:08 AM   #7
Tech B
Tech B is on a distinguished road
Hey George! How is the adapter I sent you working out for ya?
Tech B is offline   Reply With Quote
Old 02-11-2010, 09:40 PM   #8
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
Nick?? Is this you??
It fits perfectlly with my autometer oil temp sensor. Its installed now, but I can't drive the car yet (gotta wait for a few more weeks... still winter here).
Thanks!!!!!
86GXL
Old 03-25-2010, 02:32 PM   #9
gkarmadi
water jacket mod?!!
gkarmadi's Avatar
A follow up. After test driving the car a few car in spring weather (53*f-61*f), the oil temp @ idle is 180*f (the same w/ coolant temp).
But after a few hard pull (3 times) the coolant showing 190*f while the oil temp is 200*f-205*f.
I do have an oil cooled turbo only, is this a contrubute factor for oil temp higher than coolant after only a few pull??
86GXL
Old 03-25-2010, 03:59 PM   #10
A factor, yes, the reason no.
205* is nothing to worry about. I wish my oil temps would get that high.
Old 03-26-2010, 02:36 AM   #11
/\ lol, maybe you went a little overboard, huh T? Also, how about the oil Thermostat you're using? Any plans to make it open at a higher temperature?
From Grassroots Motorsports Magazine:
One reason for lower oil temps is viscosity. Perhaps try using a high quality, lighter weight oil? It will heat up faster, yet still protect the engine just as well.
If you want to play around with oil viscosity, the oil temp gauge is your best friend.
Old 03-26-2010, 08:47 AM   #12
I didn't go overboard with the sizes based on what the FD guys are running. With the rad yes, not the coolers. I went overboard with the ducting.
My oil pressures are too high so I need to play with the shims in the front covers bypass. When those get to a reasonable amount, I'll play around with the viscosity a little. The t-stat is a 140*, just like the factory, I might swap it for a 180* if I can find it.
Old 03-26-2010, 11:12 AM   #13
knonfs
knonfs is on a distinguished road
Are you using a FMIC?
knonfs is offline   Reply With Quote
Old 03-26-2010, 11:13 AM   #14
knonfs
You are not using the mocal anymore? Mocal states "The thermostat opens at 180°F/82°C +/-10°F or +/-3°C"
Old 03-26-2010, 11:20 AM   #15
I am still using the Mocal. From what I understand there are two different models, a 140* and a 180*. I BELIEVE that I have the 140*. I will have to check as I know exactely where the destructions are that came with the unit.
