Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > NRS Rotorsports
NRS Rotorsports www.nrsrotorsports.com (Canada) Ceramic apex & corner seals for rotary engine applications
Old 04-18-2009, 12:03 PM   #16
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
A ceramic side seal would be very difficult to make. The part is so thin and it requires a good amount of pressure to grind the material, I'm afraid it would dissintegrate.
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
glassman is offline   Reply With Quote
Old 04-18-2009, 12:18 PM   #17
wow, 130psi! Keep it up man, you're the forefront of the future of the rotary!!
Old 04-18-2009, 12:49 PM   #18
glassman
Premium Vendor
glassman's Avatar
Thanks! It will be nice to see how this does after some run in and a hot comp test.
NRS Rotorsports
Old 04-28-2009, 10:06 AM   #19
glassman
Premium Vendor
glassman's Avatar
corner seal testing
I just talked to Ernie and Ray (PFS) should have his car on the dyno by Friday. We will have some results very soon
NRS Rotorsports
Old 05-31-2009, 10:31 AM   #20
glassman
Premium Vendor
glassman's Avatar
We should have some results soon from Ernie, they havent run the engine yet with the corner seals but it shouldn't be much longer!
In about a weeks time I will have some thicker c.s. springs. The FD spring is 0.016" thick, I am having some 0.020" and 0.025" springs made for testing. Likely we will not hard face them just yet, that can be done after when we have a better idea which thickness is best. I will supply Ernie with a set of each thickness and the next time the engine is out he can throw in the 0.020" thick springs followed the next time with the 0.025" thick. Unfortunately it will be a lot of work just to change the springs but it's the only way to know for sure what can be done and what works best. I'll put up pics when the springs are finished.
NRS Rotorsports
Old 06-25-2009, 06:29 PM   #21
glassman
Premium Vendor
glassman's Avatar
Ernie might get the engine fired by this weekend and he has promised to let us know how it goes on the dyno. I cant hardly wait to get his impression of how the corner seals act. With the bigger turbo and now a bridge port we don't have a direct comparison so we'll see what the #'s look like anyhow.
NRS Rotorsports
Old 06-25-2009, 08:00 PM   #22
ErnieT
ErnieT's Avatar
ErnieT is on a distinguished road
Engine is fired up and will hit the dyno tomorrow. Would have happened to day, but the shop lost power around noon and didn't come back on till 6pm.
PFSupercars Built/Tuned 781rwhp all Turbo/Bridgeport
ErnieT is offline   Reply With Quote
Old 06-25-2009, 10:45 PM   #23
Ernie,
Take some video of your dyno.. Can't wait to see the numbers!
Old 06-26-2009, 09:37 AM   #24
Bryan@BNR
Bryan@BNR is on a distinguished road
Good luck Ernie.
I have a good friend that studies bigger turbochargers. If you want me and him to get you a turbo for 1000 plus hp let me know. If you want 2500 Hp let me know hahaha.
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
Old 07-12-2009, 08:56 PM   #25
Boostmaniac
update?
Old 12-04-2009, 11:33 AM   #26
Monkman33
Still Building my FD
update?
Old 12-04-2009, 04:04 PM   #27
ErnieT
ErnieT's Avatar
Have not been on this forum for a bit so I appoligize. The car is running great. In fact I won my first event at Englishtown a couple weeks ago beating a Supra in the finals. I ran a 9.87. My car just barely made 700rwhp at 30psi. I can turn it up more, but I like the idea of having the motor around for awhile.
http://www.youtube.com/watch?v=I5jADKzessw
Old 12-04-2009, 07:27 PM   #28
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
hahahha, "no Hondas, a pair of rear drive cars"
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
Old 12-26-2009, 10:44 PM   #29
thewird
thewird's Avatar
thewird is on a distinguished road
So whats the word on these seals . I'm opening my motor up which currently has your 3mm one piece ceramic seals thats been running for 32,000 km. I'm going to be putting 3mm 2-piece seals and I would like to put in ceramic corner seals if possible too. So whats the status of the corner seals? Thanks.
thewird
thewird is offline   Reply With Quote
Old 12-28-2009, 03:36 PM   #30
glassman
Premium Vendor
glassman's Avatar
I have just 2 sets of 3mm 2pc seals left. Do you need a set soon? Might be a good time now!
The corner seals are on hold for now until I can get some data from Rob @ Pineapple on the 2mm set he has. We had a couple of failures with the initial two sets used so we want to start from scratch with static drag tests in a fixture and then increase loads via thicker springs to see where we can pressure to and still not exceed the factory seal for drag. Then Rob will clearance them to the rotors that will be built into an engine from there. The corner seals as made seem to fit on the tight side in new rotors (some slots can vary as much as 0.001" on the small side) so we want to eliminate any issues with binding in the slot. There were too many unanswered questions with the first two uses so Rob will head up all further testing and documentation. Likely they will be used along side factory apex seals in the first build so that they are the only change made. I will try and get an answer from Rob as to when he can start testing. He has the factory springs hard faced with the extra twist but I still need to get him the thicker springs we made and I think we'll get him to use the standard FD CS spring for best comparison. He can try the hard faced ones later.
Happy trails,
Sven
NRS Rotorsports
