Old 05-23-2008, 11:16 PM   #1
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Any Weber guys here?
As some of you know, I've been getting ready to do a 5-8 PSI blow-through setup with a 45 DCOE and S5 turbo on my streetported R5 13B, and I've got a couple of questions.
First: I have two options as far as which carb to use. The first one is an old-style "made in Italy" 45 DCOE. It looks to have pretty high mileage and the throttle shaft seems like it's a little tweaked, and doesn't close fully without an external throttle return spring. Seems to work okay otherwise. The other carb is a newer "made in Spain" model that seems to be in a little better shape overall, though it's a bit dirty. It also has some weird brown/orange sand-like gunk in the float bowls, which will have to get cleaned out. I have heard the Italian ones are better somehow, but I can't find details as to why. Which one do you guys think I should use? I'll probably use the plastic floats out of the Spanish one either way.
Second: I'm currently having a very choppy cruise at less than about 1/4 throttle. More than that and it's smooth and has decent power. Deceleration is smooth, idle is acceptable. I read one post that suggested that the float levels might not be set right, which is possible since I haven't checked them yet. Any other probable causes? Current settings are listed below:
Main venturi: 40mm
Aux. venturi: 4.5mm
Idle jet: 65F9
Main jet: 180
Emulsion tube: F11
Air corrector: 175
Accel. pump jet: 60
Since I'm still NA, I'm not going to bother trying to get it perfect yet. I'd just like to solve the cruise problem for now and get it tuned for real once I have boost and an air/fuel gauge.
Old 05-27-2008, 09:40 PM   #2
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
It sounds to me like your float level is off a little causing your stumble. All else seems to be good.
Be careful not to exceed the 8 psi. The floats will crush under anything much more than that. No one makes any metal floats for the Webers to get decent boost.
Old 05-29-2008, 06:15 AM   #3
Sterling
Premium Vendor
Sterling is on a distinguished road
Don't let a little dirt & varnish throw you off. A bent shaft is bad news.
As far as I know, there should be no difference in quality/craftsmanship.
Sterling is offline   Reply With Quote
Old 05-29-2008, 11:47 AM   #4
tom93r1
tom93r1 is on a distinguished road
I have a 48DCO in the REPU. In my experience if the floats are set too high you get fuel dripping inside the throttle bodies. Just look in there and you can see some dripping going on. It will even flow back out the intake side and drip on the motor. Too low and you will run out of fuel quickly on a full throttle run.
The first thing I would do is stick a wide band in there if you dont have one already. I had the REPU running somewhat OK for 5 years, but with my recent rebuild I installed a wide band and in about 15 minutes of jetting I have it running way better than it ever did in all the time I owned it before! Its really quite a chore to get things right without one, and I suggest you have it tuned perfectly before you even start working on your blow through setup.
Dont make a decision based on how clean the carb is. These can be completely torn down, cleaned and rebuilt in an hour.
tom93r1 is offline   Reply With Quote
Old 05-31-2008, 07:44 PM   #5
PercentSevenC
Custom User Title
Yeah, I know a dirty carb is not necessarily a bad carb. In fact, often the dirt and grime help preserve it.
But after looking at them again, both carbs are in about equal condition, including the throttle shafts. I'll probably use the Italian one with the plastic floats since the linkage is already set up.
No drippage in the throttle bodies as far as I can tell. I swapped in the plastic floats and it feels like it might have improved slightly, but the problem is still there. I haven't noticed fuel starvation issues on full-throttle runs. What should the level be for the plastic floats?
Yes, a wideband would be nice, but they're too expensive for me. A narrowband will have to do, as non-ideal as that may be.
Old 01-22-2009, 07:54 AM   #6
730RWHP12A
when you run a 45mm carb with 40mm venturies its going to be choppy at part throttle. install a 36mm venturi and she will drive much smoother. the choppyness is the carb switching back and forth from idle circut to main circut.
rotaryshack.com
Old 09-06-2009, 12:36 AM   #7
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
Accel pumps could be as high as 90's
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
www.nrsrotorsports.com
glassman is offline   Reply With Quote
Old 09-06-2009, 02:32 AM   #8
PercentSevenC
Custom User Title
Hmm, this thread is back, eh? May as well update. As it turned out, the problem was that my idle jets were just way too big. I'm using 50F9s now, and it's nearly perfect. Go figure.
Took a bit of a detour to play with superchargers and 4-barrels for a while, but I'm back on track to finally get the turbo installed, probably over the winter.
Robert: I may try some smaller main venturis, but not because of drivability problems (because I don't really have any anymore). I'd just like some extra low-end. Under 4K there's just not that much there. The turbo should help with that, though.
Old 09-07-2009, 02:51 PM   #9
Jeff20B
Jeff20B's Avatar
Really? Let's do an order from that pipe place soon. Let's also start fabbing up a carb hat. It'll be winter before you know it.
Old 02-23-2010, 07:29 PM   #10
craig3x
craig3x is on a distinguished road
I am having a similar problem. Choppy at cruising speeds. But on a long deceleration, it seems to "build up" or something, cuz when I get back on the throttle, it bogs and then farts a huge backfire out the exhaust and sometimes dies. Most of the time I have to pull over and wait a few minutes then fire back up. I do have a wideband, but it is digital and not sure how accurate. (question, i had to install a switch on my wideband guage to go back and forth from each rotor because I am using 2 0xy sensors. has anyone solved that problem?)
here are my jetting settings:
Weber 48 IDA on a 13b street port. (4 port)
250 MAIN ( I know this is big, but my problem is at lower RPMs. Ordered a 190 and 220)
70 Idle
50 Pump Jet
F-11 emulsion tubes
160 Air Corrector Jet
Please help if you can! Thanks
craig3x is offline   Reply With Quote
Old 02-23-2010, 10:37 PM   #11
730RWHP12A
70 Idle
50 Pump Jet
F-11 emulsion tubes
what is the acc. bypass jet in the bottom of the float? it has to be a zero
rotaryshack.com
Old 02-23-2010, 10:45 PM   #12
craig3x
can't seem to find what you are talking about. can you refer to this schematic and let me know what you're talking about? Also, how important are the air horns? (number 58 on the schematic)
http://webernorthamerica.com/pdffiles/48IDA.pdf
74 porsche 914 with 13b rotary
http://www.youtube.com/watch?v=d0CUlLecxbo
73 914 porsche 1.7
Old 02-25-2010, 04:44 PM   #13
craig3x
Also, I just measure and found out I have 47mm venturis. Seems huge, but thats what the carb came with on this car. Also, I am not running the airhorns. Is that bad? what do they...and the venturis do exactly. And what is affected by their size??
73 914 porsche 1.7
Old 02-25-2010, 05:06 PM   #14
70 Idle
50 Pump Jet
F-11 emulsion tubes
Are you worried about the O2 sensors failing when one isn't being used (up to temperature)? or are they working and you are just not reading one of the outputs?
Old 02-25-2010, 05:50 PM   #15
craig3x
It's just annoying cuz I can only read 1 output at a time. I have to flick the switch to read the other one. This makes it hard to tune and read while driving
73 914 porsche 1.7
