KTEC
rebuilding a motor, something strange?
I noticed there was slight scar on the rotor housing near the exhaust port. but there was nothing broken in the motor. So as i inspected the rotors, they looked fine also. until i checked the apex seal slot. the tops of them have burrs on almost every edge. I know this isnt normal, cause i havnt noticed this before in other builds i have done.
so would filing the burr off ever so slighty be ok? what might have caused this?
Scars on the rotor housing could be from a chunk of carbon flying around.
Burrs on the apex seal groove? Some rotors come with machined rotor faces - you'll notice the lines. This causes the jagged edges on the apex seal grooves...if this is what you're talking about? -Ted |
KTEC
just to be a little more clear. this is what i mean by burrs on the apex seal slot. The red indicates where the burrs are. They are exagerated a little in the picture i drew.
and yes, these rotors have the lines, so they might be the machined ones. If this is indeed the case. filing the burr off a bad idea? (im not artist)
