Go Back   Rotary Car Club > REGIONAL FORUM > Southeast > Tennessee
Tennessee Mazda Rotary Car Club of Tennessee
Old 03-21-2010, 10:39 PM   #691
fire85gslse
fire85gslse's Avatar
Originally Posted by lilring View Post
Rear struts for the hatch
I think there are two of these on my work bench in the garage
Old 03-21-2010, 11:35 PM   #692
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Originally Posted by My5ABaby View Post
There's a few pimple thingies on the gauge hood, but otherwise it's good. All of the plastic is good except for 3 spots by the windshield. Two are where you screw the dash into the firewall (not really needed) and one is the left most clip to hold the defrost vent cover piece (the long piece under the windshield) on. You're in Antioch, right? I could run it by if you want and let you check it out.
Mine is riddled with sun damage "pimples" all over the gauge cluster hump and in front of the warning light surround. I'm in Smyrna off of hwy 24 exit 70, Almaville Rd.
1988 GXL
Old 03-22-2010, 05:20 AM   #693
FC Zach
FC Zach's Avatar
Yeah.. its Tuesday the 23rd right? I will be coming in my gray RX8. The RX7 suspension is shoot so it doesnt move much
Yep, tomorrow @ 6p.m., Toots on Broad
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-22-2010, 09:14 AM   #694
My5ABaby
My5ABaby's Avatar
I might actually have the 7 at the meet for once. It's actually better at transporting parts than my 6. Can't really fit much in the 6 as far as bigger parts.
Community Service Manual
RotorWiki
Old 03-22-2010, 09:23 AM   #695
I'll be there in the SA if I get the axles back in and get the brakes done an bled on Tuesday (taking the day off). The left wheel bearing was growling pretty bad so I'm glad I'm doing it... and I have tunes!
Old 03-22-2010, 09:33 AM   #696
My5ABaby
My5ABaby's Avatar
79 SA has tunes and I don't. I really need to work on this whole no radio thing. I need something to drown out my trannys whining.
RotorWiki
Old 03-22-2010, 07:01 PM   #697
FC Zach
FC Zach's Avatar
HVAC switch illumination ? ?
To all you 2nd gen owners, I've always been curious but forget to ask whenever we meet up. Do your selections on the switch unit (such as the "head", "feet", "defrost", etc.) illuminate? I cant see the damn things at night to make the selections so I have to use the dome light to differentiate them.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-22-2010, 07:30 PM   #698
My5ABaby
My5ABaby's Avatar
About 1/2 of mine work. I'm not sure if the lights are burned out or if the actual buttons don't work. I'll have to do some experimenting.
RotorWiki
Old 03-22-2010, 08:04 PM   #699
fire85gslse
all of mine worked in my white fc and my last black TII
Old 03-22-2010, 09:54 PM   #700
RoughRex
RoughRex's Avatar
Originally Posted by 83Rx7 View Post
I will show up Tuesday. Zach,thanks for the drive shaft.
Anyone have these items they want to part with:
New Driveshaft seal-non turbo for 91vert
center air vent for 91vert
Drivers side electric window switch for 91 vert
Bring them with you if you want to part with them.
Thanks
Rich
I have a center air vent for S5 (Same vent for coupe and vert I think?) but one of the horizontal pieces is broken off and missing. I'll bring it tomorrow it's yours if you want it.
The bottom row where you select temp lights up on mine... most of the time. The top row where you select which vents you want air at, the lights are all out. I tried replacing the bulb but no luck. It's a candidate for the soldering iron if I ever get around to pulling it back out again... such a PITA.
See you all tomorrow!
1988 GXL
Old 03-22-2010, 10:28 PM   #701
FC Zach
FC Zach's Avatar
Good to know that the lights in mine worked at one point in time, forever I actually thought it was designed that way.
"I tried replacing the bulb but no luck. It's a candidate for the soldering iron if I ever get around to pulling it back out again... such a PITA."
Now I just have to find out why there not working, I'll get on this possibly in the morn.
"About 1/2 of mine work. I'm not sure if the lights are burned out or if the actual buttons don't work. I'll have to do some experimenting."
Thats how my clock is, it works when it want to and I'm not sure if its the idiot light display, the connection in the back, or both? ? ? not a big enough problem for me to care enough about so I ignore that little issue.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-22-2010, 10:45 PM   #702
RoughRex
RoughRex's Avatar
The idiot light cluster issue is caused by cold soldering... I bought a "reman" from Icemark because I was too lazy to fix it myself. I'd be willing to bet the logicon suffers from the same issue. The buttons on mine light up it's the back lighting that shows which button is which that is out on mine.
1988 GXL
Old 03-23-2010, 06:19 AM   #703
fire85gslse
yep, it is the typical 2nd gen electrical issues. They all will have them at some point.
Old 03-23-2010, 06:20 AM   #704
fire85gslse
Have fun tonight guys. Im in memphis and wish i could be there with the rx2
Old 03-23-2010, 08:04 AM   #705
FC Zach
FC Zach's Avatar
Chad, is that the old yellow one I used to have? Is it drivable yet? I was talkin about that car last night.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
boners, djs a poofter, extra boners, middle tn, super boner, who added boners?
