Old 04-12-2010, 07:42 PM   #61
project86
Can't.Make.Up.My.Mind.
project86's Avatar
i really like how you have your ignition set up. where did you find those?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 04-12-2010, 09:44 PM   #62
Christopher W.
Christopher W. is on a distinguished road
Those are the igniters that came with the Electromotive TEC3R engine management system. The mounts are custom made by Defined Autoworks.
Christopher W. is offline   Reply With Quote
Old 04-12-2010, 10:07 PM   #63
adopt me
Old 04-12-2010, 11:03 PM   #64
THE_REAPER
THE_REAPER is on a distinguished road
This a great build beautiful 20b
YOU MIGHT BE A KING OR A LITTLE STREET SWEEPER, BUT SOONER OR LATER YOU'LL DANCE WITH "THE REAPER"
THE_REAPER is offline   Reply With Quote
Old 04-23-2010, 12:43 AM   #65
KaiFD3S
KaiFD3S's Avatar
I love your build Christopher, it makes me want to start mine, I have been debating on selling the car or going all out on it, after seeing this I may just start my build after this summer.
Can't wait to see it all done.
RE AD FACER 9
Old 10-17-2010, 09:35 PM   #66
Christopher W.
I got some pictures from Logan recently. The engine has been together for a while. I should have some new pictures coming in the not to distant future...
Old 10-17-2010, 09:39 PM   #67
Christopher W.
Hand built mufflers..
Old 10-22-2010, 11:07 PM   #68
This is gorgeous!! With that oil pan design... is it done that way to avoid hitting the front sway?
Old 11-02-2010, 01:10 PM   #69
Christopher W.
It is to clear the steering rack.
Old 11-19-2010, 07:24 PM   #70
NoDOHC
NoDOHC's Avatar
Hand-built mufflers! That is totally cool - you need to get sound clips once you get it together.
Old 11-20-2010, 12:36 AM   #71
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
this is an amazing build sir.... I love your anal attention to detail,I have it too... only my pockets don't go as deep (yet)
this is a setup and a build quality that I think every rotary owner would to drive, if not own/show off... superb quality
this makes all my ideas look like rubish in comparison...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 11-20-2010, 10:50 AM   #72
FDwarrior
Defined Autoworks
FDwarrior is on a distinguished road
I see this car almost every day, and the pics don't do it justice. This has to be the cleanest FC I have seen at least.
FDwarrior is offline   Reply With Quote
Old 11-26-2010, 12:52 AM   #73
nate
Not a fan of rust...
nate's Avatar
nate is on a distinguished road
Its so inspirational to see builds this perfect.
88 vert
87 SE
nate is offline   Reply With Quote
Old 12-24-2010, 02:55 PM   #74
GtoRx7
GtoRx7 is on a distinguished road
Have some more pics of the building process. We had to move the engine 1.75" further back into the chassis to make room for the large radiator and a/c. Started with a stock transmission mount, cut and fabricated a new structure onto it. Then, had our driveshaft shop shorten the driveshaft 1.75". Since the shifter would no longer line up, we used a 1st gen shift tower and modified the shift rod. This puts it very close to stock location.
Then built a oil pedestal bracket, and bolted the assembly to the shock tower. The pedestal will allow us to have twin -8an feed lines to front and rear of the block. We have found through racing that this is a desired modification.
Next was time to mock up the radiator and condenser, as well as the oil cooler. We relocated and fabricated the fill neck on the radiator to give additional hood clearance. Machined spacers were made, and the condenser bolts onto the radiator. Once the ideal locations were found, a subframe that holds both was fabricated. The subframe bolts onto the car, so no welding on the chassis would be required. This will be a quick release setup similar to my track car. The radiator, oil cooler, and condenser will be able to be removed in minutes from the top.
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
Old 12-24-2010, 03:51 PM   #75
gmonsen
The Ancient One
gmonsen's Avatar
gmonsen is on a distinguished road
Logan... This is absolutely the best FC in the country. Interesting that you had to move the engine back, but it looks like it all worked out well.
(Let's talk next week. I'm a go on the headers...)
Gordon
1993 Rx7 R1 20b NA
1994 Rx7 20b supercharged project
1991 BMW 850 6 speed
1991 BMW E30 M3 Evo II
gmonsen is offline   Reply With Quote
