Old 07-10-2010, 11:15 PM   #1
Boiled the brakes, fronts faded bad (not rx7)
so i acquired a 1980 toyota celica that i am using as my rallycross car and eventually my rally car while i build the rx7 (so i can learn on this slow car and build the rx7 correctly).
anyway, been doing some seat time in this car and found the brakes to boil pretty bad. Didnt think you could actually HEAR it boil either...
but i digress, the fronts faded bad, the rears not as much and it became rather unstable if you had to use the brakes for any reason.
So what is a good cure for this? Im going to flush the brakes and replace with the best fluid i can find. But is this enough? Or should i look to whats available for larger brakes? Im sure some other toyota model has something a tad larger.
Old 07-11-2010, 03:26 AM   #2
Kentetsu
Kentetsu's Avatar
Duct some air to those badboys and let 'em breathe man!
Maybe some decent pads too. But if that doesn't do it, you'll probably have to go with larger discs to help dissipate the heat.
Any chance that the original fluid was in shitty condition? Maybe water contaminated?
Old 07-11-2010, 05:08 AM   #3
Cheapest and easiest "fix" would be to run better brake fluid...
If it's not enough, then go with ducting...
Almost anything else is EXPENSIVE.
Old 07-11-2010, 12:24 PM   #4
im going to flush and replace the brake fluid and see how that pans out.
Old 07-11-2010, 01:24 PM   #5
Tinman
Tinman is on a distinguished road
Try the simple stuff first. Fresh fluid is a must but also look to see if the caliper slides are working smoothly and not binding in anyway that could cause the pads to drag after the pedal is released. Make sure the lines and hoses are in good condition and not kinked or collapsed. I have seen situations where the pressure in the caliper could not be released due to a faulty line or collapsed hose causing severe drag. A maladjusted master cylinder pushrod can cause the same problem.
If everything in the hydraulic system is in perfect working condition the best thing to do to reduce heat is pad choice and or driving style.
Tinman is offline   Reply With Quote
Old 07-11-2010, 10:41 PM   #6
josh18_2k
if the pedal went to the floor, its the fluid.
if the pedal stayed hard(ish), but the car wasnt slowing down, thats the pads.
Old 07-11-2010, 11:16 PM   #7
the pedal stayed pretty decent but the fluid was certainly boiling. I heard it and saw it and it was damn hot coming out of the top of the master cylinder. Im going to flush the fluid and inspect the brakes a bit.
Old 07-12-2010, 10:05 AM   #8
Kentetsu
Kentetsu's Avatar
You might also (not sure) want to take a look at your braking method.
Good firm braking applied when needed = cooler rotors
Less pressure applied for longer periods = overheated rotors
