Old 07-22-2010, 10:55 PM   #1
codysa22c
codysa22c is on a distinguished road
1980 rx7 gas tank????
does a 1980 rx7 have a drain plug on the tank?????? if so where is it at
codysa22c is offline   Reply With Quote
Old 07-23-2010, 01:16 AM   #2
Kentetsu
Kentetsu's Avatar
Sorry, but you're outta luck there. I don't think they added them until 84-85.
Basically, you have three choices:
1. Remove the gas tank and dump it out. This has the added benefit of allowing you to clean the tank (possibly take it to a radiator shop to have it boiled and sealed, not too expensive) while you have it out. You can also clean up any rust spots and undercoat it to help it last a bit longer.
2. Remove the fuel line from the carb, aim it toward a bucket, and let the pump run the gas out.
3. Bust out the garden hose and try to siphon the gas out without swallowing/inhaling any of it (I don't personally recommend this route).
Good luck man.
Old 07-29-2010, 03:33 PM   #3
RX-7 Chris
RX-7 Chris's Avatar
As far as I know they added the drain in '81
Old 07-29-2010, 08:40 PM   #4
bailing
Location: hi-tech zone of Zhengzhou, Henan province, China.
bailing is on a distinguished road
Is it true?
bailing is offline   Reply With Quote
