Old 05-02-2010, 06:01 PM   #16
yzf-r1
Banned
yzf-r1 is on a distinguished road
David, what is your overall opinion of the BNR Stage 3 manifold? Can you work some "magic" with it?
yzf-r1 is offline   Reply With Quote
Old 05-02-2010, 08:54 PM   #17
Garfinkles Motor Works
I do not know what Brian is doing with the manifold.But I have taken his 3rd stage turbos and reworked the four cast iron parts to get a great set up .Brians work is tops as far as I have seen. And I have had other venders sets as well .
Old 05-03-2010, 10:20 AM   #18
R1_Stormrider
Traveling in Stygian
R1_Stormrider's Avatar
R1_Stormrider is on a distinguished road
my car is currently equipped with a billet aluminum turbo from Precision. i got the 6262 T4 w/ .81 A/R. from what i hear billets spool up pretty quick and that Garrett has jumped in with this new tech as well.
if you go single, maybe you should look into them. as for myself, i havent seen a difference yet but thats because my car isn't ready. if they spool up faster i will be sure to post about it
93 RX-7 FD R1
R1_Stormrider is offline   Reply With Quote
Old 05-26-2010, 09:45 PM   #19
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
Originally Posted by N3philum View Post
at what rpm would the GT35r make full boost? what about the BNR's? I will not be going non sequential if i stay twins. If i am going to make the twins act like a single, ill go gt35r.
I know this is an older questions, but I am sure others are wondering...
A good Gt35R turbo system should be at 15psi by 3200rpms in 4th gear..
Rx-7 Turbo Kits, Engine Building, and Parts
www.turblown.net
1Revvin7 is offline   Reply With Quote
Old 07-27-2010, 08:21 PM   #20
yzf-r1
Banned
Old 08-03-2010, 01:59 PM   #21
RE_guru
RE_guru's Avatar
RE_guru is on a distinguished road
i went with a 62-1 from turbonetics and undersized the ar ratio. with the ceramic ball bearings i am at full boost a 3krpm.
'94 Mazda Rx-7 montego blue
'88 Mazda Rx-7 se (SOLD)
'04 Mazda Rx-8 GT 6spd (daily)
Control Freaks www.cfdrift.com
All Your apex R belongs to US!
RE_guru is offline   Reply With Quote
Old 08-12-2010, 08:54 PM   #22
XLR8
XLR8 is on a distinguished road
Spool time will also depend on your intercooler configuration.
I'm currently building my GT35R setup.... Same setup as CrispyRx7's.... Made 422whp on 15psi. with a SP engine.
I will be running a RE Vmount setup with a stock port engine. Should be interesting to see how the spool is.
I vote 35R. Going single has many advantages. Yes, the spool is slower than the twins, but with the right configuration, it can be quite fast. Get that heat factory out of there. Go single with water injection & a good tune. Your engine will thank you....
XLR8 is offline   Reply With Quote
Old 10-14-2010, 11:44 AM   #23
POPCORN
Five slice baloney
POPCORN is on a distinguished road
what ar u got ? t3 t4 ?
POPCORN is offline   Reply With Quote
