Old 07-28-2010, 10:38 AM   #16
ducktape
Hardcore
ducktape's Avatar
ducktape is on a distinguished road
On to page 2!
Painted the first coat of rattlecan silver. Pretty happy with the color; Was worried it would look too "bass boat". A couple of flat areas are visible in the paint, I'll sand and respray those tomorrow.
ducktape is offline   Reply With Quote
Old 07-28-2010, 11:32 AM   #17
MaX PoWeR
MaX PoWeR is on a distinguished road
This is outstanding!! I have seen a project build on the forums in a while. Keep up the good work. Can't wait to see her run!
MaX PoWeR is offline   Reply With Quote
Old 07-29-2010, 08:54 AM   #18
ducktape
Hardcore
ducktape's Avatar
Okay, last cage pics for a while. Wetsanded the whole deal and gave it another coat. Turned out pretty good. I broke out the old carpet and put it back in (not pictured). I HATE this cranberry interior color with a passion. I wish I had been able to get a hold of a black or grey interior, but I was never able to find one in good shape. I guess I'll live with it.
Okay, enough boring interior stuff. The only reason I spent so much time on it was because it needed immediate attention due to the years of neglect.
Tonight, I'm going to pull the engine out and start working on it. Stay tuned.
Old 07-29-2010, 02:27 PM   #19
ducktape
Hardcore
ducktape's Avatar
Just started looking at T6 manifolds... Depressingly expensive to buy outright. I've been spoiled by dirt-cheap 13b parts.
I've seen a couple of designs I like, may try to reproduce something similar to the Kiwi design. I got a quote from a local shop that does good work for around $900 material and labor (2 years ago). At the time that seemed excessive, but now it sounds like a steal. Anyone have any suggestions?
Old 07-29-2010, 09:42 PM   #20
-xlr8planet-
-xlr8planet-'s Avatar
If its not too much trouble, could you take pics of the rear of the roll cage? does it extend under the car?
Thanks!
Old 08-01-2010, 08:17 PM   #21
C. Ludwig
Rotary Masochist
Thought about dying the carpet?
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 08-02-2010, 12:24 AM   #22
ducktape
Hardcore
ducktape's Avatar
Nah, I should just learn to live with it. That cage has the headliner and trim locked in. Going to try shampooing it, if that doesn't work I'm going to raid the carpet out of Josh's parts car. In fact, I might just try to take that whole car off his hands. It has a maroon interior, working door handles, crank windows, and a windshield.
PS: I keep thinking about moving the motor further back. I figured out how to make the shifter work with the motor pushed back to the firewall.
Old 08-02-2010, 03:08 PM   #23
lh6601
Down with OPP
lh6601 is on a distinguished road
Nice muthafuckin project man
86 base, TII swapped, Rtek 2.1, some other things. Daily driven.
lh6601 is offline   Reply With Quote
Old 08-02-2010, 10:24 PM   #24
ducktape
Hardcore
ducktape's Avatar
It's so damned hot and humid right now, I'm just not getting much done. I think I'm going to switch back to working on this thing late at night to avoid the high temps.
In any case, the engine is out and shortblock'd. I'm starting on cleanup, and trying to figure out if I want to crack it open for some porting.
All the numbers match. D-series, #212. Arguably the most desirable, with the improved e-shaft and meatier side plates. I am very lucky to have this motor!
I'm taking notes on what needs to be done to this motor. I think I have decided to cut and file the EGR cavity on the UIM. I'm going to build my own fuel rails and use top-feed injectors for the primaries. I'll use an N/A 13b water pump and housing with double-belt pulleys. I can't remember if I sold my REW flywheel; I hope not.
Just for shits and grins, here's what a 1st gen looks like with a 2nd gen crossmember.
Old 08-03-2010, 04:36 PM   #25
C. Ludwig
Rotary Masochist
You need a flywheel that bolts to the 20Bs auto counterweight.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 08-03-2010, 04:39 PM   #26
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Nice!
Old 08-03-2010, 08:54 PM   #27
Rotary no Densetsu
Haters gonna hate
Rotary no Densetsu's Avatar
Rotary no Densetsu is on a distinguished road
We are currently making a manifold for the 20b. I can send you some pictures when its finished, if you are interested still. Should be pretty badass.
Here are a couple pictures I have now for my car.
Like I said, let me know if you are interested, i dont mean to hijack your thread. lmao
Rotary no Densetsu is offline   Reply With Quote
Old 08-03-2010, 09:56 PM   #28
ducktape
Hardcore
ducktape's Avatar
It will be a while before I buy a manifold, but I am interested. Are you building it with equal length runners? Send me pics and details when you finish it.
Old 02-06-2011, 01:27 AM   #29
ducktape
Hardcore
ducktape's Avatar
This thread isn't dead!
After being out of work for almost a year, I had some financial obligations to take care of. So this project didn't really pick up steam until November. I've been taking pics since then, but haven't posted. The goal is to have it rolling this summer. Going to miss DGRR, but there will be other events.
As it stands the 20b is at LMS-EFI for port work. I have the LIM and UIM, and am prepping them for powdercoat. I've selected my transmission: Liberty Tremec TKO 600 5-speed with the faceplate option. Really doing my homework on gear ratios, and taking measurements to fit. Based on what I have learned, I think I may need to move the motor back another 2-3 inhes. This tranny would fit perfectly in the stock position if you could put the shifter in the middle of the dash. :P
Old 02-06-2011, 01:39 AM   #30
ducktape
Hardcore
ducktape's Avatar
Core Support
At some point in this car's past it was involved in a low-speed collision on the drivers-side front corner. The damage wasn't really noticeable until I tried to replace the panels. valence and fender would not line up no matter how hard I tried. I actually managed to ruin a perfectly good fender by crushing it with the door when I opened it.
I bought a $150 rear-quarter wrecked '83 GS with a blown motor for parts. The donor car core-support was cut out and welded in place once the backing tube was pushed forward a bit. Here's a couple of pics:
