Old 09-11-2010, 12:58 AM   #16
Mateepay
Mateepay is on a distinguished road
Cleaned the engine finally and it is the oil meetering pump that's leaking I ordered a gasket to fix it for now but i also blew a Coolant line right under the oil cooler T_T
Mateepay is offline   Reply With Quote
Old 09-11-2010, 11:18 AM   #17
Kentetsu
Kentetsu's Avatar
...which probably means that the oil cooler is leaking too. This is typical. Oil drips down onto the rubber hoses and causes them to detiorate, then finally blow. If so, then you need to replace the orings in the beehive. Not a big job, this was the first repair I ever made on my car.
Good luck.
Old 09-15-2010, 11:56 PM   #18
Mateepay
i replaced the hose ordered the other coolant hoze under the beehive doing a tach swap this weekend and it wasnt the gasket it looks like the oil lines from pump to carb guess thats next
Old 10-12-2010, 08:35 AM   #19
Mateepay
found the issue rotted oil injection lines problem fixed receently came into the possetion of a 84 with a disk rear en sidedraaft intake manifold and a delorto 48 ida also had a rb header so stoked ont the 83's build now
Old 11-12-2010, 08:12 PM   #20
Mateepay
updated pics rb headers going on next week then startup
