Old 01-20-2011, 08:02 PM   #16
warwickben
sa rat rod
Any updates?
Old 01-21-2011, 10:41 PM   #17
gmonsen
The Ancient One
gmonsen's Avatar
gmonsen is on a distinguished road
Warwicken... Yep. Three failures on the runners!!! The fourth one worked and the whole thing should be done by mid next week. Its a real pain getting the 120 degree bend just right with a tapered runner without crimping it. We ended up taking 2 inch pipe and mandrel bending it to the right curve and then cutting a "slit" in it and hammering the sides of the slit together to get the exact taper. They look good. Victor is "trumpeting" them into the plenum now. So, some pictures soon of the runners and then the finished piece. Then, another week to some new numbers!
Gordon
1993 Rx7 R1 20b NA
1994 Rx7 20b supercharged project
1991 BMW 850 6 speed
1991 BMW E30 M3 Evo II
gmonsen is offline   Reply With Quote
Old 01-21-2011, 10:49 PM   #18
Damn, sounds like a lot of fun. Can't wait to see the finished product though. Hopefully the rewards are worth the pain
Hey Gordon, just an FYI, there's a group of us heading to Dave's one the 29th. 4 of us from the forum and maybe a 20B FD as well.... just in case you've got nothing going on next saturday
Old 01-22-2011, 09:02 AM   #19
gmonsen
The Ancient One
gmonsen's Avatar
TitaniumTT... I'll be there if the weather isn't lousy, if you guys are on for sure. I stop by Dave's every so often and just sit there all day doing nothing while Dave talks on the phone and tells me we can talk soon... He may have the new paint booth done. You can also see a few new things on my car that I haven't shown yet.
Gordon
1993 Rx7 R1 20b NA
Old 01-22-2011, 09:43 AM   #20
warwickben
sa rat rod
I'm a metal worker by trade. Next time you build one try this. Turn a steel stake down to the taper you need. You can heat it up and curve it as u need. Cut two strips of sheet metal and hammer them around the metal stake trim and weld both halfs togarther.
Can't wait to see more pics.
Old 01-22-2011, 10:10 AM   #21
Gordon, we're on for sure... unless there is a TON of snow... if that's the case we all may head up early to beat it? Either way, I'm planning on being there to test a few coils and see if two rx8's can match one RE in power then of course probably get blown out of the water by a 20B turbo FD... should be fun.
I know those days at Daves all to well.... he's got damn good coffee though
Old 01-22-2011, 10:33 AM   #22
hades
at work we use a product from Lydall to help protect the cab from the turbo. The product is has a pressure sensitive adhesive backing, a 1/2" fiberglass core and a stainless steel outer skin.
This does a great job of protecting metal and fiberglass from the turbos--which are a bit too close.
I wish work didn't throw out my 8' rolled sample.. or i would send you a piece of it just to see how it.
Just throwing some ideas out there. I designed aftertreatment components for Peterbilt the last few years. Fighting heat has been a challenge. I do have some pretty cool materials to try out though.
good luck.
This is going to tear
Old 01-22-2011, 10:50 AM   #23
gmonsen
The Ancient One
gmonsen's Avatar
Ben... I actually had that idea and it would have been next. We tried filling the runners with sand before bending them and there was still a small crimp in them. Bending a full 2 inch diameter aluminum pipe first and then slitting it and moving the two sides together seems to have worked.
Brian... Good deal. I guess Ray's bringing up Chris' car? Its funny. That car was here for maybe a total of 4 -5 years. Now, I've got Davin's black touring in the garage for a time while he's in California. I should start charging for storage...
The motor is ready to be assembled and we are just waiting on the intake to be completed to put it together. We have my original headers and a new set that Logan (defined autoworks) made for me that he claims will add 20-25 foot pounds of torque. So, we'll be doing a lot of dyno work in about 2 weeks?
Gordon
1993 Rx7 R1 20b NA
Old 01-22-2011, 11:39 AM   #24
Yeah, if Ray can work a day off he'll be there. I didn't realize Ray ended up with Chris's car... that's really awesome. I've been wanting to see that beaut
If you're offering free storage... I may take you up on it so I'm not tempted to take the FC apart once I get her back together
Have you thought about taking the al pipe to an exhaust shop? They usually have a bunch of mandrels that should be able to bend without crimping. I've gotten to the point where I'm going to be building my own tubing bender in the very near future. Too many things can be built much more attractively with some mandrel bends and I'm getting to the point where off the self bends just aren't really cutting it anymore. Plans can be bought online for a few bucks, then it's just a day of millling and welding. Dies are usually about $150 iirc.
Old 01-22-2011, 11:47 AM   #25
gmonsen
The Ancient One
gmonsen's Avatar
Brian... We were welding up a tube that tapered and then bending it. Taking a 2 inch pipe and bending it first works much better. We have all the tools, just did it backwards, I think.
And, yeah, Ray got Chris' car. He stole it for the price of a motor. Car still needs cosmetics.
Hades... Very cool. If worries come up, I'll reach out for some ideas?
Gordon
1993 Rx7 R1 20b NA
Old 01-24-2011, 05:28 AM   #26
warwickben
sa rat rod
fill with water not sand. it makes it so much easier. only way sand will work is if you can weld like a plungers on one side and compact the sand. sand has air pockets that can mover around and deform the metal. water not so much.
Old 02-01-2011, 10:29 PM   #27
gmonsen
The Ancient One
gmonsen's Avatar
So, we are finally going on the manifold. It was a pain getting the runners right. The final method was to make it in 2 halves and then weld them together. We tried every other way of doing it (thanks, Warwickben) and it didn't come out right. The first 3 of these looked perfect and measure out exactly. It was a bot more complicated than we thought. Again, its the tapering while bending that's so tough. Either one without the other works fine, but its tough to do them both together. These will be done this week and back to get put on the motor next week. I am very excited that we will see some exciting results.
Gordon
1993 Rx7 R1 20b NA
Old 02-02-2011, 12:50 AM   #28
gmonsen
The Ancient One
gmonsen's Avatar
Victor is working thorough the night to get these done. They are made up in halves and welded together. That's the only way we could get the complex curves and tapering to work just right. Please don't mind the welds. They will not be visible once ground and polished and then painted.
Gordon
Look at the curves and taper of the runners. Very complex shape.
Notice how different the lengths of the runners were originally. The third rotor has a much longer runner than the others.
1993 Rx7 R1 20b NA
Old 02-02-2011, 09:35 AM   #29
warwickben
sa rat rod
Cant wait for pics lol.
Old 02-04-2011, 09:37 AM   #30
diabolical1
I have radioactive semen
appears to be coming together quite nicely. i can't wait to see what it does on the car. what finish are you planning on when all is said and done? coated? polished?
