Old 01-24-2011, 06:53 PM   #46
RotaryXperiment
RotaryXperiment is on a distinguished road
got mine done.
here is the before and after. thanx for the great work guys!
File Type: jpg 131718_1712938461937_1192420271_1826140_447512_o.jpg (94.2 KB, 364 views)
File Type: jpg 134726_1712938861947_1192420271_1826141_2864273_o.jpg (79.0 KB, 362 views)
RotaryXperiment is offline   Reply With Quote
Old 01-25-2011, 05:38 AM   #47
Judge Ito
Porting Master
Judge Ito is on a distinguished road
alex, u saved a pair of housings and they look real good. good luck on the build.
Judge Ito is offline   Reply With Quote
Old 01-25-2011, 04:05 PM   #48
RotaryXperiment
thanx ito.i appreciate it, goopy did a great job.
Old 01-25-2011, 10:50 PM   #49
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
wow... nice results!
depending on how bad the inside of my engine looks... youll be getting my housings.
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 01-28-2011, 04:10 PM   #50
diabolical1
I have radioactive semen
very impressive work ... and for a price that a loser like me can afford.
Originally Posted by Max777 View Post
I really like the look of this, and I think that it's great to finally have an option to machine your housings, my only question is:
Why did this take 20 years, and how come no one figured it out before? Was it lack of precision technology, or what?
i doubt if there is any one reason for why it's taken so long. maybe it's technology. maybe it's changes in attitudes. hell, maybe it hasn't been 20 years - i mean, if Ito got a set to test 3 years ago, then there had to be a period of time where this went from an idea to a part-to-be-tested. either way, it's a long-awaited, welcome option for many of us, and hopefully a stepping stone to even better innovations for this engine that we love so much.
Old 01-28-2011, 08:42 PM   #51
Ian
REIAN
Ian is on a distinguished road
I would say things like this are starting to appear because
-Mazda prices are insane
-they are probable stopping production or already have and there is limited stock.
What needs to be done is recoating/refinishing. All my engines (I have at least 12 housings last time I counted. I thought I had 6 until I move a few boxes. Man 20 years makes stock piling!) have the dreaded corner seal triangle wear or have apex damage. Makes them useless with todays current offerings.
I'm going to drive down to Goopy Performance after my DGRR trip
1989 Turbo II. Track Car
1988 10thAE. Garage Queen 400+rwhp
Ian is offline   Reply With Quote
Old 02-23-2011, 07:42 PM   #52
diabolical1
well, i figured there wasn't a point in starting a NEW thread just to say the same thing, so ...
i met with Jonathan (Goopy) last Friday and brought him a pair of REW housings that have seen better days. i probably could have used them as they were, but i figured i'd have him resurface them so i could see it all for myself. i need them for a build right now and figured with resurfacing, they could give me a little more time before the engine has to come apart again. the rear housing was a little more beat up than the front, but he checked them out and told me he could get them done by Tuesday. i got a call (registered at around 0900) from him Tuesday morning saying they were complete and i could pick them up.
bottomline ... they came out awesome! they were worth every penny and i would recommend him to anyone in the rotary world. we talked for a bit and i can tell this guys knows his shit! not only that, but he showed me a few ideas that he came up with for all sorts of problems that come about - real, simple, and effective solutions that blew my mind with their simplicity and ingenuity. this guy oozes passion for rotaries and he's friendly (this is coming from a guy that doesn't have many friends and is not too friendly ).
anyway, long-story, short ... Goopy Performance is truly a breath of fresh air and i will gladly go back in the future whenever needs above my skill-level arise.
1
by the way, i'll try to post some photos of the housings before and after. i will also try to see if i can get some compression numbers when it's running, too. i plan to make a thread for this particular engine build when i get the time, so i may not post them here, but rather maybe a link.
Old 02-24-2011, 05:15 AM   #53
Judge Ito
Porting Master
1
glad it worked out for u. jon does have a passion for this engine we all have come to respect. I'll be releasing some information soon that will benefit everybody.
Old 03-03-2011, 08:33 PM   #54
Rotary Inspired
Rotary Inspired is on a distinguished road
Work w/ Jon is nothing short of a great experience. I recommend him. Thanks agian Jon.
If you wanna become ASE certified buy the RX7.
Rotary Inspired is offline   Reply With Quote
Old 03-26-2011, 07:06 AM   #55
Judge Ito
Porting Master
I just dynoed my nephews turbo II using Goopy's refinishing job. this is a series 4 engine. 8.5 to comp. on rotors. Rx7 made 400rwhp@ 15lbs of boost. goal is 22 psi of boost but the car would not hold boost. leakin boost all over. engine still pulls 14.9 inches of vacuum. this car is an underdog to say the least and still made respectable power for 15lbs. we will fix the boost leak and go back to the dyno.
Old 04-04-2011, 06:46 PM   #56
Judge Ito
Porting Master
12A bridgeport
I just did a 12A bridgeport for a daily driven Mazda B2200 pickup. using Goopy's refinished rotor housings with apex seals. I wanted to do a compression test as close to real numbers as possible. I did not lube the side housings with oil and I did not lube the rotor housings with oil. basically a dry build and dry test. I did not want the lube oil to add to compression numbers. engine made 125psi equally on both front and rear rotor. enjoy the pics..
Old 04-05-2011, 08:26 AM   #57
RotaryXperiment
great stuff ito!
Old 04-05-2011, 02:36 PM   #58
Judge Ito
Porting Master
engine fired up with half a crank. i'll have a video up soon.. brap,brap,brap.. sounds pretty healthy this 12A..
Old 04-05-2011, 03:17 PM   #59
Jwteknix
Jwteknix's Avatar
Jwteknix is on a distinguished road
sweet ride
-88 SE -Wht on Blk, Goopy motor, HKS TO4r, Haltech PS 1000, FD UIM, a1000 pump & FPR,....(underconstruction)
-91 tII -Blk on blk -(SOLD)
Jwteknix is offline   Reply With Quote
Old 04-06-2011, 06:55 AM   #60
Judge Ito
Porting Master
i'm getting alot of pm's on what apex seals I used on the 12A build. I used Goopy Apex Seals..
