Old 03-11-2011, 10:45 PM   #16
GreyGT-C
GreyGT-C is on a distinguished road
hello bridgeport!
GreyGT-C is offline   Reply With Quote
Old 03-11-2011, 11:39 PM   #17
Waffles
Waffles is on a distinguished road
so much for my plans to use a modded Nikki. I wonder of my holley 650 in the basement is enough....
Waffles is offline   Reply With Quote
Old 03-12-2011, 08:38 AM   #18
That actually looks really good. Once cleaned up it should be good to go, you got lucky!
Whew, that is a nice port
Old 03-12-2011, 09:52 PM   #19
Waffles
So with the discovery of the bridge port, do you think this setup will help?
intake:
Racing Beat bridge port Holley intake
Holley 650 double pumper
Quickfuel 150 gph fuel pump
Quickfuel adjustable fpr set for 6psi
Old 03-22-2011, 01:58 PM   #20
Waffles
So parts are starting to come in for the rebuild.
racing beat Gasket/o-ring kit (showed up yesterday)
FD corner seal springs from pineapple racing
Viton oil ring inserts from Atkins
3mm solid corner seals from Atkins
The tension bolts are in good condition and i plan to reuse them, and the apex seals were low miles. Can you guys think of anything i would be missing?
Old 03-22-2011, 03:59 PM   #21
one320fc
one Apex @ a time
one320fc's Avatar
one320fc is on a distinguished road
I would think the 650 should be enough for the bridge...RB uses the 465 for a stock and SP 12A and 650 for the 13B bridge port
And if your build is like mine..money is an issue, anything you already have saves you $$ to put into somthing else.. Don't run a holley Red pump the buzzing will drive you nuts! and pick out a good FPR also..
1983 Limited Edition SOLD
1977 Mazda REPU I will work on it one day I sware!!
1987 T2 um after the repu is done??
2013 Chrysler 200 DD
2009 Dodge Journey
94 Volvo 850 N/A The slowest car I have EVER owned!!!
one320fc is offline   Reply With Quote
Old 03-22-2011, 05:25 PM   #22
Waffles
I am used to the hum of a fuel pump this wont be my first car with a huge fuel pump, but I am thinking the fuel supply and return line would be to small for the pump. I will most likely have to get a new pump and reg.
Old 03-31-2011, 11:50 AM   #23
Waffles
Well I was about to reassemble the engine last night only to find out my Faïence while cleaning my desk threw out my brand new FD corner springs and my Atkins solid corner seals
Now i am waiting on parts AGAIN!
Old 03-31-2011, 05:28 PM   #24
rx71king
rx71king's Avatar
rx71king is on a distinguished road
shit...that sucks big time ....the 650 will work well...
rx71king is offline   Reply With Quote
Old 06-19-2011, 08:47 PM   #25
Waffles
Any ideas how to strip this thick of grease??? I am stripping it down to paint, so it does not have to be paint safe.
Old 09-19-2011, 08:21 AM   #26
Waffles
Well marriage and moving really slows stuff down. I was out in the garage for the first time in over a month and got the engine assembled.
