Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants |
High Horspower Sheet Metal 20b intake manifold
After lots of time on the dyno, we have made a economical way to heavily increase horspower for turbo and n/a 20b's. We require a 20b intake core for the modification. This setup uses a 90mm throttle body. All the port entrances are fully venturied for optimal flow.
Price is $1100.00 ![]() ![]() ![]() ![]()
DEFINED AUTOWORKS Where concept meets results Black 1994 FD 4-rotor 610rwhp all motor Red 1970 Mazda R-100 with 10a Black 1974 Mazda Rx4 Black 1984 Gsl-SE 13b-re streetport 230rwhp |
What are the power gains seen from this?
10hp n/a and 15-25hp turbo.
Have you made any manifolds for FD with 13BREW mated to GZ LIM?
I'd be very interested in that. |
Outside the "box"......
15-25hp? Do you have a graph of this? At what boost level, power output, rpm and with what turbo? 15-25hp is not a lot in a turbo 20B for $1100 when all you have to do is run 1psi more boost to achieve the same, if not more power...
-J
" Life is full of trials and tribulations, misery is optional." -Mark D. White RIP man, we love you... ![]() We specialize in Rotary, Japanese, European and Exotic performance forced induction cars. We also custom build 3/4 multi-rotor engine setups for the street or track. We are the only authorized Fujita Engineering dealer in the USA. Call for authentic FEED parts. Call for ECU tuning. http://www.facebook.com/pages/Gorilla-Race-Engineering/43530496660 |
#6 | |
Gaining power by increasing boost is completely different than gaining horsepower by reducing restrictions. As you already know. There will be times when no more boost can be added for a horsepower gain. I admit this intake did not create as much power as we wanted. But it is still a bolt on gain. I dont have a dyno chart on a turbo 20b because this has only been tested on our n/a 20b. 15-25 hp will be at 10-16psi with a proper sized turbo.
Bookmarks |
Thread Tools | |
Display Modes | |
