Old 06-02-2011, 10:48 AM   #1
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Fuel pump write up with pics
I removed my how to over on 7club for a few reasons. Figured i would put it here.
Disconnect your battery. Then the fuel pump access door is behind the Driver on a USDM spec FD. Lift up the carpet and you'll see it. If you have a Bose stereo system you'll probably have to remove it. There should be 4 screws holding the door down.
Lift up the fuel door and unclip the wiring harness
You can either unclip the ground or unscrew it i went with unscrewing it.
Set the door off to the side and unscrew the fuel line connectors
Clean off the area for obvious reasons
Take all the screws out of the fuel hatch
You'll need to push the 2 fuel lines out of the way. The line on the right hooks into a clip i found it easier to pull the line of the clip so you get more play in the line
Lift out SLOWLY as to not hook the float on anything
Remove the screw on the back of the rack, mine was extremely tight
The + and - wires are different sizes so you can't really screw that up but hey maybe you can. I left 1 wire on just to make sure i didn't
With the new fuel pump make sure and hook up the fuel bag thing
by pressing on the washer
Put the spacer and O-ring in the fuel neck
Put the fuel pump space and cover on the fuel pump
Tadaaa
Put it all back in the car and start her up. I let my car idle for quite a while to make sure there was no air in the fuel lines.
Please add in anything i might have forgotten.
Old 06-13-2011, 11:23 AM   #2
rotarybeat1287
Member
rotarybeat1287's Avatar
rotarybeat1287 is on a distinguished road
Was that an oem replacement or aftermarket pump? I know same rules would still apply regardless but I'm thinking of replacing mine soon. I don't really know the condition of it.
rotarybeat1287 is offline   Reply With Quote
Old 06-13-2011, 10:36 PM   #3
hades
good write up. more.
This is going to tear
Old 06-14-2011, 12:15 PM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
That was a Supra aka Nippondenso pump. It would be the same for a Walbro or any other direct replacement pump.
Old 06-15-2011, 10:51 AM   #5
Actually the Walbro is a bit smaller and requires more work to fit. The Supra/Nippondenso is the only pump I know of that is a direct drop-in replacement of the stock pump.
Good write-up! Thanks for adding to the write-ups/how-to's on this forum. I always felt it was a bit lacking here, but it's getting better. WOOT!
Old 06-17-2011, 07:27 PM   #6
prrex4ever
prrex4ever's Avatar
Great write up, thanks for sharing.
Old 06-24-2011, 07:28 PM   #7
hades
I have almost a full tank of 1 year old gas that I would like to get out of the tank. Probably better to burn it in the lawnmower.
Good processes to pump the fuel out?
Old 06-26-2011, 08:42 PM   #8
dvo
dvo's Avatar
dvo is on a distinguished road
nice write up! thanks!
dvo is offline   Reply With Quote
Old 06-30-2011, 06:29 PM   #9
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
remove plug from bottom of tank...let it drain...put plug back in.
Old 07-01-2011, 02:23 PM   #10
RXtacy
RXtacy's Avatar
I was thinking exactly the same thing... Just take out the drain plug.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-04-2011, 01:11 PM   #11
hades
well fuck me side ways...never knew there was a plug.
Old 07-14-2011, 12:35 AM   #12
If you don't feel like draining it out of the plug, you can hook a long hose to the outlet of the pump, jump the pump/grnd in the diagnostics box, turn the key forward and let the pump do the work. But I mostly did this because I had a diffuser on and didn't feel like taking it off to drain the tank haha.
Old 07-14-2011, 01:13 PM   #13
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I'm repping you for that one... It made me lols....
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 07-19-2011, 10:44 AM   #14
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I could see that. Since my battery is in the back i would have just used some extra wire and jumped it strait to the battery.
Old 07-19-2011, 06:42 PM   #15
It also helps because you don't have to jack the car up to get a bucket under there, you don't have to swap buckets really fast when they get full, and you can verify the pump is working if you're having issues starting the car LOL. I've had to pump my gas out several times so I can almost do it in my sleep lol.
