Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Defined Autoworks
Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants
Old 05-31-2009, 03:08 AM   #1
GtoRx7
GtoRx7 is on a distinguished road
The Defined Autoworks 20b conversion kits
Here is the very unique, best solution to install the famous 20B into a 3rd gen FD3S.
Pricing-
Full conversion, TIG welded steel motor mounts base kit- $1,670.00
Full conversion, TIG welded steel motor mounts retain a/c and p/s deluxe kit $2070
Optional color anodizing of aluminum parts- + $150.00
Modify stock 20B intake + $350.00
Common questions-
Q: How is this kit different from regular 20B subframe kits?
A:This is not a subframe replacement. You retain your factory subframe, and not a single modification to the stock subframe is made. The steering rack is not moved and that is the most important difference. This allows NO bump-steer. Since all the OEM parts are used, no danger of weak welds, or mis-alignment occurs.
Q: Can I keep the stock transmission, and will the transmission stay in its factory place?
A: Yes, the factory transmission is retained, and not moved from stock. This means no cutting of the PPF frame is made, thus making a much safer 20B powered Rx-7.
Q:Can I keep my air conditioning?
A: We now offer a version that keeps the a/c, and will work with turbo and non-turbo 20b's
Q:Can I keep my power steering?
A: Yes the kit is made to use all 93-95 accessories, and power steering.
Q: Can I use the factory 20B intake manifold?
A: Yes, but it must be sent in to Defined Autoworks to be sectioned and lowered, to clear the hood.
Q: Can I still use this kit with the factory twin turbo's, and large single turbo's?
A: Yes, both stock and single will work just fine. Just specify during ordering if its a twin turbo.
Q: Will this kit work on Right Hand Drive cars as well?
A: Yes, it will work just fine with Right Hand Drive.
Q: Why not just use the 13B rear plate on the 20B, and FD engine mounts?
A: This 13b rear plate method will not solve any problems of mounting a 20B. The 13B iron will need ported, and machined to work with the 20B. Then add to the fact it will use the weaker FD engine mounts, why go through the hassle? Our mounts are FAR stronger, bolt onto a all stock 20B, and drops into the factory subframe. This mean no teardowns are needed, and less work/aggriavation results.
Q: If this kit is so good, why does everyone else do it differently?
A:Good question
Q:What do I need to send in to be modified?
A: The Steering rack, P/S bracket, 20B oil pan, Alternator tensioner(only for base kit), 20B intake manifold.
Q: What is the turn-around time of the kit?
A: Once we receive all the items, it will take 3-8 weeks.
Pictures of the blue anodized kit. Note alternator location, and the new tensioner. And the machined waterpump outlet.
Picture of the new deluxe kit, which keeps a/c and p/s.
Tig welded motor mounts, with twin turbo provision. Shown with the now standard delrin mounts, and grade 8 hardware.
Machined tensioner, and ball bearing idler pulley. Grade 8 bolts and hardware. Anodized blue option.
Modified factory 20b oil pan, with anti-sludge coatings, and new drain plug in the new location.
Just a few tensioners in three color styles. More colors are available.
The modified p.s bracket with alternator relocation.
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
Old 07-14-2011, 04:47 PM   #2
thewird
thewird's Avatar
thewird is on a distinguished road
What would the cost be if your not interested in PS or A/C and the steering rack is already modified for full manual? What exactly are you modifying on the 20b intake?
Also, can the engine be lowered any? I currently have my engine lowered about 1cm.
thewird
thewird is offline   Reply With Quote
Old 07-14-2011, 10:36 PM   #3
GtoRx7
It would be $1250 without modified steering rack or a/c kit. Still need the a/c bracket to mount the alternator, which we build. The engine sits on the steering rack, so it cannot go lower without lowering the rack. Which is bump steer
DEFINED AUTOWORKS
Old 07-14-2011, 11:01 PM   #4
thewird
thewird's Avatar
Why can't the alternator go in its original location? Does it hit the hood? Thanks.
thewird
Old 07-15-2011, 09:20 PM   #5
GtoRx7
Correct, it will hit the hood
DEFINED AUTOWORKS
Old 09-02-2012, 12:40 PM   #6
thewird
thewird's Avatar
Some more questions since I finally acquired my 20b block. Will this setup work with the 20b water pump or is the FD water pump used? Also, what is the cost if we don't need the LIM chopped? Thanks.
thewird
Old 09-03-2012, 08:33 AM   #7
GoopyPerformance
Rotary parts manufacture
Cant go wrong with Defined...Innovators for sure!!!
GoopyPerformance is offline   Reply With Quote
