Old 08-18-2011, 10:43 PM   #1
<track>7
<track>7 is on a distinguished road
Xcessive Motor Mounts
Thought I would cross post this in case anyone here needed the info.
Mounts arrived today and I installed them this evening. First impression is they are less annoying than the Himni mounts. The xcessive mounts also have less vibration than one stock mount and one Himni mount which is what I resorted to in order to drive the car without getting pissed off. Install was a bit of a pain since your putting a square peg in a round hole, literally. Overall I'm pleased with them and the only real issue is a resonance between 1000 and 1500 RPM when pulling away from a stop. Other than that they dampen similar to stock but remove alot of slop from the drivetrain. Shifting is much improved and the car responds quicker on direction changes.
My name is D.Cobb and I approve these mounts!
<track>7 is offline   Reply With Quote
Old 08-19-2011, 07:31 AM   #2
<track>7
Forgot to mention I bought the 65A version of the mounts.
Old 08-19-2011, 08:25 AM   #3
Gregory Casimir
were can i get a set for myself?
Gregory Casimir is offline   Reply With Quote
Old 08-19-2011, 09:21 PM   #4
<track>7
http://www.xcessivemanufacturing.com/home.html
Old 08-20-2011, 10:44 AM   #5
Garfinkles Motor Works
How much do they cost ,if I can ask.
Old 08-20-2011, 04:40 PM   #6
scotty305
scotty305 is on a distinguished road
price on the site is $189.99 , Mr. Garfinkle.
<track>7 , which Himni engine mounts did you have? Their site claimed they were offering softer durometer mounts and I bought a set of those. The vibration is manageable for the most part, but there is a VERY noticeable resonance around 1500-1800RPM when pulling away from a stop.
scotty305 is offline   Reply With Quote
Old 08-20-2011, 05:48 PM   #7
<track>7
The Himni mounts I bought were red. No clue which ones they were but I asked for the street version. If I got the race version I wouldn't be surprised. Their website showed the mounts had shipped the day I bought them. Email confirmation as well. Seven days and many, many unanswered calls later I filed a complaint with Paypal seeking a refund. Miraculously they shipped the same day. Your mileage may vary.
Old 08-20-2011, 05:52 PM   #8
<track>7
As an aside, the only reason I didn't buy Garfinkle's brace was the cost of my one blown mount and his brace was double the Xcessive mounts. On top of that I still had to install the brace. At this point I was tired of crawling under the car in 105F temps to work on it. I still don't like the resonance but I'm willing to live with it.
Old 08-22-2011, 01:56 AM   #9
Interesting design, I've never seen that before.
Old 08-24-2011, 04:13 PM   #10
Radial GT
Radial GT is on a distinguished road
That is a very interesting design. I have solid Poly mounts and they work just fine, less than 1/2" movement. I don't see why they made them so stinking complicated. Less is more in the FD, less is more.
Radial GT is offline   Reply With Quote
Old 08-27-2011, 01:54 PM   #11
scotty305
Radial GT, I think the idea is to prevent excess movement without transmitting a lot of vibration to the subframe. Eliminating metal-to-metal contact should keep things quieter inside the cabin.
Originally Posted by TitaniumTT
The problem is there are a select few that actually know WTF they're doing...
...the bulk of them are keyboard mechanics and theorists that can't see past thier mistakes.
So, if each group posts an equal amount, there will be a tremendous amount of shit out there...
Old 08-27-2011, 08:48 PM   #12
Signal 2
Viable Fossil
Signal 2's Avatar
Yep. A combination of a bolt-thru design and hard durometer can get old over time for a streeted car. I think it started out really old-school with solid aluminum cylinders, then hockey pucks, then poly of various degrees of hardness. And now it seems Noltec and Xcessive have discovered alternatives.
Jim
VR R1 FD
Old 08-29-2011, 12:33 AM   #13
I had Noltecs before and they were nice, but they are too tall. Makes you need a spacer to raise the strut bar.
Old 08-31-2011, 06:21 AM   #14
Signal 2
Viable Fossil
Signal 2's Avatar
I've got Noltecs now. Didn't measure them, but visually they didn't look any taller than the OEM. My engine is higher, but I figured it was due to the pan brace and forgetting to have the arms milled 3/16".
Regardless I wouldn't give them up. They're as quiet (NVH) as OEM but control engine movement really well.
Jim
VR R1 FD
Old 09-01-2011, 12:24 AM   #15
Well the oil pan brace definitely raises it, but the Noltecs I had raised it too. I didn't have a pan brace back then and I had trouble fitting the same strut bar on, so I used spacers. My roommate has a pan brace and the Noltecs right now and his is WAY too high to use a strut bar, unless he uses some fairly thick spacers. I do love the Noltecs, just can't use them with the other things I have.
