Old 03-22-2008, 10:50 PM   #1
one320fc
one Apex @ a time
one320fc's Avatar
one320fc is on a distinguished road
cleaning engine bay
any one have tips on cleaning the manifolds? I have some light oxidation on the gsl-se and wanted to clean it up a bit for the car show at DGRR !!! I will post up some pictures later on today.
one320fc is offline   Reply With Quote
Old 03-23-2008, 12:17 AM   #2
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
Kinda depends on what types of tools you have. If you don't have a bunch to choose from, a cordless drill with a wire brush on the end will clean it up nicely. Probably want to use a brass brush since it is a softer metal. Don't forget the safety glasses as shards of the brush will come flying off.
If you have a compressor and an angle grinder, I'd suggest a mandrel with a 3m scotch brite pad. This would make quick work of it.
Hope that helps.
Old 03-23-2008, 08:19 PM   #3
I know you probably want to leave the manifold on - for a quickie job, try the aluminum polish they sell in the small cans at autozone -
Rub hard until it turns black and then wipe the black residue clean...
Old 04-08-2008, 07:08 PM   #4
Kentetsu
Kentetsu's Avatar
I just picked up a couple of small wire brushes for the dremel for $3 each. Doing everything that is aluminum on the engine. The brushes cut right through it and shine it up almost like chrome in a matter of seconds. Nothing to it...
Old 04-09-2008, 09:31 AM   #5
^ But it'll oxidize really quick if you do that, just an FYI - I did that years ago.
I used to polish a lot of parts by hand and its hard to keep them looking good. Sanding with a dremel and 100 grit paper and then again with 600-800 makes a nice surface, than hit it with some jewelers polish and you're set.
We ended up just powdercoating most parts though since it lasts longer w/ less maintenance. I'll have to do a write-up at some point w/ pics from my previous parts.
Old 04-09-2008, 08:44 PM   #6
Kentetsu
Kentetsu's Avatar
I wonder if there's a way to preserve the finish once its been polished? I thought about a good coat of wax, but figured it would just cook off. Is there a type of clearcoat that would withstand the temps, and be able to bond directly to metal? Gotta be some way to keep the bling dammit!
File Type: jpg Sterling carb and jet removal X020.jpg (184.8 KB, 13 views)
File Type: jpg Sterling carb and jet removal X021.jpg (108.3 KB, 11 views)
Old 04-11-2008, 08:21 PM   #7
rx7carl
rx7carl's Avatar
rx7carl is on a distinguished road
Yea mothers mag polish or eagle one. They leave a waxy coating that preserves the shine for a bit.
www.pbandjracing.com
rx7carl is offline   Reply With Quote
Old 04-12-2008, 03:22 PM   #8
Kentetsu
Kentetsu's Avatar
Thanks for the tip Carl, I'll give that a shot and see if it helps. After polishing, the aluminum does develop a dark/dull color after only a day or so.
I'm installing a 2nd gen water pump housing this weekend. I was amazed at the weight difference! That 1st gen housing weighs a ton! I also got a new 1st gen water pump, which looks like it will fit on the new housing, and it is also aluminum (which is cool, and a lot lighter than the original).
Old 04-13-2008, 01:53 PM   #9
$100T2
Big Daddy
$100T2's Avatar
POR-15 makes a clear version of their stuff. You can hit it with a hammer and it won't come off. Doesn't get any better than that.
http://www.por15.com/
