Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Defined Autoworks
Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants
Old 05-31-2009, 03:16 AM   #1
GtoRx7
GtoRx7 is on a distinguished road
One of our customer cars, 20b turbo FD
Here is our 20B project that we have finished up a few weeks ago. Its taken many hours of custom fabrication, and what we feel is a unique approach to a 42R 20B.
Specs--
--C series 20b, All new rotor housings, dynamically balanced, NRS ceramic apex seals, Race rotor bearings, our own oil/ coolant modifications. Circuit Street Port intake and exhaust.
--Exedy triple plate clutch
--GT42R turbo
--Tial 60mm wastegate
--Electromotive Tec3R ecu
--Electromotive inductive coils
--D.A. custom turbo manifold, 321 stainless
--D.A. custom 3.5" downpipe and exhaust 304 stainless
--D.A. subframe conversion kit, and modified lower intake
--D.A custom intake box and filter
--D.A custom intercooler and radiator
--D.A custom intercooler pipes
--Twin setrab oil coolers
--Aeromotive kevlar braided oil lines
--Twin supra fuel pumps
--Aimsports race dash display
--Kaaz limited slip diff
Ever since the start of this project, the customer and us wanted it to have a full stock subframe. We also all know how much heat a 20b turbo produces, so a V-mount proved essential. After a lot of fitting and measuring, the GT42R turbo combined with stock subframe, a V-mount, and stock trans location proved very difficult. But with a bit of hard headiness, and creativeness it started to come together smoothly. The end result was worth it, placing the turbo backwards! This makes for much less weight over the front axle as well. A custom air box had to be made, and alot of heat shielding was added anywhere possible. Even with back to back dyno runs, the intake temps never got much above ambient. On the street the coolant and oil temps stay very cool, and after lots of hard abuse, never see much past 90C. The spool-up is great, power is broad to 8500rpm. So far its made 575rwhp at 15psi.
Here are the pics!
AIM sports dash display mounted and wired in. This unit is NICE!
Custom undertray.
Dyno charts
So that is the car, hope you enjoyed it. More pics are in the 20b section.
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
Old 09-05-2009, 06:02 PM   #2
Hey, I just saw the vid for this on street fire, the car is sick, I love it!
PS: Is there a reason for leaving the stock cluster behind the race display? Was it cost or were the stock gauges necessary for something?
Old 10-05-2011, 05:55 AM   #3
DriFD3S
DriFD3S's Avatar
DriFD3S is on a distinguished road
Wicked cool!!
Live the DriFD3S or die trying.
JDM True Story.
the Vacuum line, to my MAP became detached while I was legally drifting.
my engine would not rev past 2500, and idled from 300-650 and was stalling.
Fortunately, I acquired a Zip-Tie.
I fixed a catastrophic engine failure, With a Zip-Tie.
JDM FTW.
DriFD3S is offline   Reply With Quote
Old 10-05-2011, 07:11 AM   #4
A reverse mounted turbo, now there's something you don't see every day LOL. I never could have imagined that actually haha. Is the hood going to be modified with an air vent of some sort for the intake?
And 575hp at 15psi...ho-ly SHIT.
Old 10-05-2011, 08:25 AM   #5
lh6601
Down with OPP
lh6601 is on a distinguished road
Holy canolli. That's quite a feat you guys accomplished by keeping the stock subframe. Congratulations. I can't imagine how many man hours and money went into this build.
86 base, TII swapped, Rtek 2.1, some other things. Daily driven.
lh6601 is offline   Reply With Quote
Old 10-06-2011, 10:29 PM   #6
GtoRx7
Thanks guys It did make 650rwhp at 17psi when it came back for a re-tune. The hood was cut on the underside to take advantage of the RE hood ducts. With the hood shut and air filter in place it lost only 1 hp vs. no filter at all.
DEFINED AUTOWORKS
