Old 12-01-2011, 11:40 PM   #16
dabranco
dabranco is on a distinguished road
Sounds like a short with that wire, I would follow it and see where it leads, or your interlock switch failed (black and red wire), or antitheft system failed or engaged it self (black and green wire). I am looking at an 86 RX7 diagram as well if it is a different year please post and I will get you the correct wire colors.
dabranco is offline   Reply With Quote
Old 12-02-2011, 12:04 AM   #17
db86na
db86na's Avatar
db86na is on a distinguished road
the car is an 86 i have bypassed the interlock switch and i have no anti theft system it is bypassed also
db86na is offline   Reply With Quote
Old 12-02-2011, 12:13 AM   #18
dabranco
Did you check the circuit breaker relay?
Old 12-02-2011, 12:40 AM   #19
db86na
db86na's Avatar
theyy were fine didnt need reset
Old 12-02-2011, 12:42 AM   #20
dabranco
Whats your volts when the switch is in the run position?
Old 12-02-2011, 12:45 AM   #21
db86na
db86na's Avatar
0 switch only has volts on the off position
Old 12-02-2011, 08:04 AM   #22
Raksj04
I have Ultra power in me.
Raksj04's Avatar
where are you taking the reading at?
Old 12-02-2011, 10:38 AM   #23
db86na
db86na's Avatar
im am testin volts on the w/r wire on the back of the ignition switch its got 12v in the off position but is says .50v on acc and 0 on start
Old 12-02-2011, 10:42 AM   #24
Raksj04
Raksj04's Avatar
just for giggles meter at the battery and see what happens. If the volts drop way off you may have a short.
Old 12-02-2011, 11:17 AM   #25
My5ABaby
My5ABaby's Avatar
I still assert that you have a bad connection at either the battery or a ground. Check your voltage there when you try to start and at the main relay in the engine bay. I believe it's labeled XM-1 in the wiring diagram.
Community Service Manual
RotorWiki
Old 12-02-2011, 11:29 AM   #26
Raksj04
Raksj04's Avatar
I thought I have metered my car at the switch before and have similar results but the car started. post a pic of where you are metering if you can.
Old 12-02-2011, 01:26 PM   #27
dabranco
The only thing it can be at this point is crossed wire, failed relay(s), or a bad connection(s), or short(s).
Old 12-04-2011, 03:16 PM   #28
db86na
db86na's Avatar
ok so ive been tracing wires checking connections and grounds all are clean, i opend up the ignition switch that was told was working condition and it was rusted to hell so i orderd a brand new switch from mazda, how is it possible that all 4 ignition switches are bad and showing the same volts in the acc position and run position .
Old 12-04-2011, 06:13 PM   #29
perhaps a design fault?
Old 12-04-2011, 06:16 PM   #30
Raksj04
Raksj04's Avatar
you could jump wires and see if that works
