Old 04-04-2012, 08:06 PM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Camber Adjustments
Any one know of front and rear camber kits for the 1984 RX7 GSL-SE?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 04-04-2012, 08:17 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Re-Speed.
http://mrcmfg.com/catalog/
They should have most anything you need for suspension.
Old 04-05-2012, 08:50 AM   #3
Solid axle rear = No camber adjustment
Old 04-05-2012, 09:05 AM   #4
GySgtFrank
GySgtFrank's Avatar
Good catch, I missed that he was also looking for rear camber. I should pay more attention to what I'm reading.
Old 04-09-2012, 11:17 AM   #5
magpiemini
magpiemini's Avatar
Oh that sucks. No wonder rear traction can be a problem. What can be done? Use an axle from another year?
1984 RX7 GSL-SE
Old 04-09-2012, 11:26 AM   #6
magpiemini
magpiemini's Avatar
So no one makes fixed camber plates for the RX7?
1984 RX7 GSL-SE
Old 04-09-2012, 01:40 PM   #7
GySgtFrank
GySgtFrank's Avatar
None that I've ever heard of. You might try checking in the autocross/racing threads. Someone running a race only car may have addressed this at sometime.
Old 04-09-2012, 02:04 PM   #8
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I've read of some racers who bend the rear axle to achieve a fixed camber.
If you want it that badly you should get a 2nd or 3rd gen RX7.
Old 04-09-2012, 02:28 PM   #9
magpiemini
magpiemini's Avatar
Naw, this is for 24 hours of LeMons.
1984 RX7 GSL-SE
Old 04-09-2012, 06:13 PM   #10
orion84gsl
The story goes that you heat the axle tubes where they meet the pumpkin and then bend them to achieve a couple degrees. Kind of one of those might work/might get you killed ideas, but pretty sure it's been done a few times.
Old 04-20-2012, 06:33 AM   #11
eprx7
eprx7 is on a distinguished road
You got it right it has been done, but bearing life is very short.
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 04-22-2012, 01:38 AM   #12
Nutsid
Temporarily insane.
Nutsid's Avatar
Precisely. I don't recommend this at all. If you have the money, you can build an extremely competent rear suspension setup utilizing the solid rear axle without bending anything.
Considering this is a LeMons car, I say just run it.
Kindle
Nook
