Old 05-05-2012, 02:23 AM   #1
krivman65
krivman65 is on a distinguished road
Runs while cranking; dies when you let go of the key
Ok. I am stuck. I have an '84 ignition system with electronic pickups. The engine fires and runs while I am cranking on the starter, but once I let go of the key it dies. Any thoughts? There are no points, so no ballast resistor. Could it be a bad ignition switch?
Thanks!
krivman65 is offline   Reply With Quote
Old 05-05-2012, 03:15 AM   #2
FC Zach
FC Zach's Avatar
Is your compression OK?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-05-2012, 09:49 PM   #3
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Check to make sure that you have coil power on the run circuit (key on, no start). I ran into the same type of problem going from 1st Gen to 2nd Gen electronics. There was a difference in those as well. The first gen (79 RX7) ignition had power to the start, but no power thereafter and another wire carried power during both start and key on. The 2nd Gen (87 RX7) had power on one wire except during start and another wire that had both. If you have the coils hooked to the wrong wire, it could cause this problem. Best bet is to break out the multimeter and see which wires have power when.
Old 05-06-2012, 10:06 AM   #4
krivman65
Yup! Compression is fine. Ya... I'm going to look through my diagrams some more and get out there with my meter to see what happens.
Old 05-07-2012, 07:48 AM   #5
cshaw07
cshaw07 is on a distinguished road
id bet its ignition switch.
cshaw07 is offline   Reply With Quote
Old 05-10-2012, 12:44 PM   #6
GySgtFrank
GySgtFrank's Avatar
Any luck Krivman?
Old 05-13-2012, 07:47 AM   #7
lilbluescout63
lilbluescout63 is on a distinguished road
this happened to me twice once in my 79 it was the inside fuse it died at a light and i had to turn key and get it accross the road uner stsrter power and than 2nd time on my 80ls it was the back side of the ignition the tabs worked loose and the rear part was loose . micht check that.
lilbluescout63 is offline   Reply With Quote
Old 05-19-2012, 09:26 AM   #8
730RWHP12A
bad grounds
rotaryshack.com
